Page 16 of 16 FirstFirst ... 6141516
Results 601 to 630 of 630
  1. #601
    Feb 17 2018
    SE PA
    Just removed these from my drivers and passenger door cards. I kept hearing a sound like a loose screw or other small object sliding around the inside of the doors when braking or accelerating. All I did was remove the screw in the middle of the door and pry the bottom of the door card with a panel tool and 1 fell out of each side. My guess is when the port installed Audi Ring lights were installed, the tabs broke and were left behind. The sound drove me nuts. Glad it was something stupid!
  2. #602
    Established Member Two Rings Jezek's Avatar
    Jul 10 2017
    ^ Not the first time Iíve heard of that happening unfortunately
  3. #603
    Senior Member Two Rings JD23's Avatar
    Jun 12 2016
    Dallas
    Quote Originally Posted by Yabi View Post
    When I was at the Audi service center they informed me there was no need to adjust the speedometer when I went from 245 to 265 tires; apparently the vehicle auto adjusts by calculating wheel rotations. I havenít been able to confirm this but I also see no reason for them to mislead me since I was offering to pay for the speedometer to be recalibrated.
    Unless the car is using the GPS system to provide the calibration, how would the car know that the wheel/tire diameter and number of rotations per mph have changed? The would be great if indeed the case, but I have never read about that feature being implemented.
  4. #604
    Active Member One Ring ch2000's Avatar
    Jun 27 2009
    2000 S4, 2005 gti, 2018 S4
    north wilkesboro,nc
    [QU=junhojin123;13186850]034 Lowering springs installed.
    Loosen everything to drop the weight off suspension and loosen everything. Pop the steering knuckle out and undo strut tower, it comes straight off :D
    No need to undo anything else :)
    034 Springs in.
    back it goes into place.
    For the rear springs, propr the inner side of lower control arm with some sort of jack, undo the inner 2 bolts, loosen the outer bolt, and pivot the arm out. Spring will simply fall out easily. Jack is here to prevent spring shooting off and hurting people, so do not forget!
    Finally, preload everything, and done :D
    oh, and alignment.
    fortunately, camber was good to begin with, Toe was slightly off.
    little elbow grease and fixed!
    some result pics:
    Paired with 10mm spacers, and roughly 1 inch drop on 034 springs, the car is looking a lot more planted to the ground and aggressive.
    overall, the ride quality on these springs are superb. I almost want to say it's more comfortable than the stock springs.[/QUOTE]
    was it required to cut the bump stops
  5. #605
    Dec 01 2017
    Dallas
    Quote Originally Posted by ch2000 View Post
    034 Springs in.
    oh, and alignment.
    some result pics:
    was it required to cut the bump stops[/QUOTE]
    Thank you for the detailed post. When I go to do springs one of these days I will come back to this post. Drop looks spot on for what I'm going for. Not too low but low enough to clean up the wheel gap.
    Excellent to hear about the ride quality. This isn't the first time I've heard the 034 springs ride just as good if not better then stock. I wonder if the progressive profile has something to do with this. The only real thing that's keeping me from springs is seeing the longevity of the stock mag ride shocks and struts. I believe they are a little pricey if they need to be replaced.
  6. #606
    Sep 26 2018
    jupiter,fla
    I bought this car a couple of months ago. I believe he did cut them. It had only 4k when I bought it.
  7. #607
    Established Member Three Rings Yabi's Avatar
    Mar 30 2018
    2011 Toyota Prius 5
    Cary, NC
    Did a multi-layer Zaino treatment, attended a Cars and Coffee, and installed some spacers to make the wheels flush with the car;
  8. #608
    Sep 26 2018
    jupiter,fla
    washed her and added some carbon fiber pieces
  9. #609
    Mar 30 2018
    2011 Toyota Prius 5
    Cary, NC
    Quote Originally Posted by YOTAXI View Post
    Looking good!
  10. #610
    Jan 23 2017
    Mountain View California
    Is cutting the bump stocks required if you go with any lowering spring?
  11. #611
    Mar 30 2018
    2011 Toyota Prius 5
    Cary, NC
    Debadged the V6T and gave her a complete detail.
  12. #612
    Sep 11 2015
    Western NY
    Quote Originally Posted by jgtripleog View Post
    It wasn't required for the EMD springs.
    - - - Updated - - -
    I did the same thing... looks so much better without them :)
  13. #613
    Mar 30 2018
    2011 Toyota Prius 5
    Cary, NC
    Better photo of the debadge.
  14. #614
    Established Member Two Rings ZeGerman_A4's Avatar
    Mar 14 2017
    Raleigh, NC, USA
    Looks nice Yabi!
    How did you get it off without scratching the clear coat?
  15. #615
    Mar 30 2018
    2011 Toyota Prius 5
    Cary, NC
    Quote Originally Posted by ZeGerman_A4 View Post
    Looks nice Yabi!
    Hey there. I plan to do a write up but in short I used a heat gun, dental floss, goo be gone, scratch remover (to remove the remaining glue adhesive), wax (to buff out any dullness), and some detail spray (to top it off). All that and a little patience. Took about 10-minutes a side.
  16. #616
    Mar 14 2017
    Raleigh, NC, USA
    Awesome!
    I really like the result!
    Canít wait for the write up...
  17. #617
    Mar 30 2018
    2011 Toyota Prius 5
    Cary, NC
    Spent the day installing 034
  18. #618
    Jun 27 2009
    north wilkesboro,nc
    h&r sport springs installed
    https://www.flickr.com/photos/126689...in/dateposted/
  19. #619
    Mar 30 2018
    2011 Toyota Prius 5
    Cary, NC
    Looks really good!
  20. #620
    Established Member Two Rings Akoby9's Avatar
    May 02 2007
    Denver, Colorado
    Debadged and blacked out both front and back. Not sure Iíve seen as many people do the back, is there any concerns on this? I can always just peel off the tint if so
  21. #621
    Mar 30 2018
    2011 Toyota Prius 5
    Cary, NC
    Looks good mate!
  22. #622
    Aug 13 2015
    18 S4, 05 G35
    Charlotte NC
    Quote Originally Posted by Akoby9 View Post
    Looks good! I blacked my front side markers out approx 6 months ago using 3M Gloss Black Vinyl. No issues thus far.
    J
    Current
    2018 B9 S4 - 10/12mm Spacers, ABT HAS, AWE Track + Res DP, DB 102mm
    2005 Infiniti G35 Sedan 5AT - OE 350z/G35 Springs, 19" G35 Coupe Rays, HR Y Pipe + Midpipe (251whp, 235wtg)
    Lost but will NEVER be Forgotten/Replaced
    2012 Nissan 370Z S+T 6MT - K&N Filters + HPS Tubes, Fast Intentions NR CF Exhaust, EcuTek (312rwhp, 253rwtq) (Totaled by...08/28/2018)
  23. #623
    Sep 28 2010
    '19 SQ5 / '19 RS5 SB
    Boone, NC
    Cool snap J
    034Motorsport | ABT | Advan | AG | Akrapovič | AWE | BBS | BC Forged | Brembo | Capristo | Deval | Forgeline | H&R | KW | Milltek | OZ | Rotiform | Sparco | Stoptech | TSW | Unitronic | Volk | Vorsteiner | Work | and many more
  24. #624
    Jun 13 2017
    Winnipeg/Manitoba/Canada
    I just picked this up today
    Sent from my SM-G965W using Audizine mobile app
  25. #625
    Jun 13 2017
    Quote Originally Posted by danaeroS4 View Post
  26. #626
    Mar 30 2018
    2011 Toyota Prius 5
    Cary, NC
    @Akoby, Iíve tinted my rear reflectors and had no problems. I think it looks good!
    @J, love the snap, looks pro!
    @danaero, itís a great piece and easy to install. I notice they went black on the branding, mine has a white ECS logo on it. Anyway, enjoy!
  27. #627
    Jun 13 2017
    Thanks Yabi....yeah i like the stealth black lettering look to it, already have the AWE intake as well just need the computer cover like you have.
    I also have the black ECS front strut brace to install.
    Should be mostly black and carbon fiber under my hood
  28. #628
    Mar 30 2018
    2011 Toyota Prius 5
    Cary, NC
    Thatís going to look hot! Canít wait to see the final build. Curious on your feedback with the ECS Front Strut Brace. Keep us posted!
  29. #629
    Jun 13 2017
    Will do! Just gonna wait til it warms up a bit so few weeks away i think (if i can wait that long lol)
  30. #630
    Jan 08 2018
    18 S4, 18 Q5
    Minneapolis, MN
    Looking forward to seeing your carbon piece installed now that they've done away with the white lettering. Should look good!
