So one of the things that i hate about the b8 is the auto transmission shifting bumps.
From stop position - 1st gear all the way to 3rd sometimes, there is a small bump or hesitation that occurs. It feels sloppy to me, as if the transmission shifting is out of timing. This happens when its on D.
The bump happens less when its on S, and obviously not so much when its on tiptronic mode because you're controlling the shifting.
I've done some research and it looks like more people had this same problem. They claimed that there used to be a post somewhere on "how to recode the shift timing for the b8 with VagCom".
Does anyone here know how to do this? If so, can you share the thread, or list the steps on how to basically re-tune/re-code the timing in gear shifting.
Thanks in advance.
