Results 1 to 40 of 52
    Veteran Member Four Rings brad65ford's Avatar
    May 30 2005
    fl
    SRM "TRUE" High Flow 4.0TT intake system, they found the restriction!
    We all know of the existing said to be high flow intake systems on the market. Well i'm hear to share what Sean over at Silly Rabbit Motorsports has been working on for his own RS7 as well as other true power seeking guys like myself. If you don't know about SRM give them a look, they do a lot of big turbo upgrades as well as custom fab work. After working with Sean, learning about his shop and their talents/abilities I'm a customer for life. Sean has been working with multiple other performance shops over seas since there is a lot to be learned regarding going big turbo on the 4.0 motors and other restriction aside from fuel and mapping. One of the area's Sean has found to be extremely restrictive as well as very misleading since there are a few intake systems on the market (some that are very pricey) though just do not yield much or even any power increase! This is simply do to not addressing the volume / stock intake tubing at the inlet of the turbo's. Fortunately Sean is one of the most eccentric (in a good way) engineers with access to a 5 axis cnc machine to which he worked his magic. After seeing his work, we knew we were in for a treat with this system. Aside from finding any space where space doesn't exist, the welding/fit and finish would amaze most anyone that has done modifications to cars before. While I will let Sean speak about the details regarding flow/volume data increase there has already been a few guys running these pipes on there rs6's overseas and seeing really RWHP gains that we all should expect from a true high flow intake system. I'm proud to say I glad I waited till there is a system like this out that addresss the main restrictions. Thank you SRM and Sean for creating such a killer intake system for our cars. Guys if you are interested in purchasing I'm not the guy to speak with please contact Sean directly at http://sillyrabbitmotorsport.com/ , I'm unsure if he has sets waiting or in the process of being machined. Enjoy! Best Brad
    Veteran Member Four Rings lnferno's Avatar
    Oct 14 2006
    Rocky Mountains
    Any before/after track #s?
    Current: 2021 Audi SQ7
    Past: 2014 Audi RS7 Stage 2 (quickest in Colorado) | 2014 Audi S6 Stage 1 | 2011 Audi A6 Suzuka Grey Avant (1 of 1) Stage 2 | 2006 Porsche Cayenne Turbo S | 2001 Audi S4 - Stage 3+ | 2006 VW Toureg V8 | 2006 A4 Avant - Stage 1 | 2006 Audi A4 - K04 | 2001 Audi S4 - Stage 2
    Account Terminated One Ring
    Mar 07 2018
    SD
    multiple tuners have before and after data, but it will be published by them once their tuning solutions for the larger turbos are ready for release.
    May 30 2005
    fl
    Regarding my own rs7. I’ve only done dragy prior plan to see if the difference, will get new numbers soon. Honestly expecting a few extra mph. Believe Sean has data on flow difference as well it’s quite impressive
    Veteran Member Four Rings IowaRS7's Avatar
    Mar 22 2017
    69 Camaro SS
    Iowa
    Would be interesting if you could still run an intake like Eventuri with the upgraded SRM piping into the turbo.
    Mar 07 2018
    SD
    soon ^
    Nov 18 2014
    Jersey
    In for results
    Mar 29 2014
    Hampshire, UK
    RocE II, the sequel.
    I’m in for the ride
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Veteran Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    Nice- that end-end connection rather than the OEM slip-fit connection to the turbos is definitely key to the larger internal diameter. This is the exact style connection that MRC uses for their carbon fiber inlets also leading to a larger internal diameter, but their ends attach to the rubber hoses that connect to the more typical airboxes, whether it be the RS7 airbox, AWE, or Eventuri. Would be very curious to see any comparative numbers whether it be on the track or on the dyno. Very Roc-Euro-esque.
    2016 S6, mythos black, RS7 turbos, MRC inlets |Akrapovic exhaust| AMS downpipes and intercooler |Eventuri intake| Loba HPFPs |Tial wastegates| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights, OEM Euro tails |Sound: Navtv Zen-v preamp, Helix DSP Ultra, JL HD900/5 driving JL10W3 sub and Hybrid Audio speakers.
    Established Member Two Rings satinblack18s6's Avatar
    Apr 02 2018
    baltimore maryland
    Quote Originally Posted by OlyS6 View Post
    lets hope its nor 1-2 months lead time like roc euro i gave up on them
    2018 Audi S6 White
    2018 Audi S6 Satin Black
    2018 Audi Q7
    2011 Audi A4
    May 30 2005
    fl
    LOL on the roc euro comment, you guys are funny. What's funny is I almost purchased that kit 2 times but something always stopped me. Believe Sean did a comparison sometime back when he designed this unit, he saw a 3 psi drop (which is extremely impressive) between these two aftermarket kits in question and should be especially when you compared them. Don't forget guys, SRM are using a 5 axis cnc machine to create the intake elbow which is what no one has created and is the big bottle, none of all the other kits are doing this currently.
    BTW received some PM here as well as Facebook pm's, thanks guys and congrats to those that ordered their own kits. Regarding lead times, I'm not sure to believe they should be in stock would suggest contacting them directly. Mine I got within a weeks time.
    His is a photo comparing the Euro intake versus SRM's psi graph.
    Established Member Two Rings audi_5000's Avatar
    Apr 22 2011
    Las Vegas
    I stopped by SRM over the weekend and had Sean install this intake on my EPL stage 1 S6. I don't have any logs or dyno comparisons, but I can definitely feel the power increase with this intake. There is less lag and the car pulls harder. I have had the Roc Euro and RS7 intake and this definitely outperforms those two. Highly recommended upgrade!
    Veteran Member Four Rings HeelBuff's Avatar
    Mar 06 2014
    2014 Audi RS7 APR stage 2, 2017 Audi Q7, 2013 Audi S5
    TN
    Quote Originally Posted by audi_5000 View Post
    That’s what he made and recommended for my car when he made the hybrid turbos. It makes sense to me more than other intakes because you double the diameter of the inlet thus greatly increasing potential airflow.
    Jan 17 2017
    Can we start a group buy?
    Feb 25 2014
    Texas
    While awesome to see others coming to the table with solutions, he is not the first to recognize this restriction
    These are the MRC inlets compared to the RS inlets. About 7 of us running these for some time now.
    And I totally understand not everyone cares for aesthetics, especially under the hood...but that intake looks very Roc-Euro-ish
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    So does this fit (benefit) stock s6 turbos and s6 airboxes?
    Feb 25 2014
    Texas
    Quote Originally Posted by Dasquade View Post
    Doesn't seem likely
    10.65 @ 129mph
    Sep 07 2010
    Belgium
    Quote Originally Posted by Ze_Nardo6 View Post
    Doesn't seem likely
    Might be wrong but tought the s and rs turbos shared the same inlet diameter?
    Rs airbox fledge is interchangeble aswell i tought so just a mather of making the pipes match lenght and maybe curves.
    Question: what are their prices (shipped to Europe + taxes = worth it)?
    Never the less, nice if it would work
    Jan 22 2017
    New York
    Doesn't seem likely
    +1
    Nov 22 2016
    Olympia, WA
    Dasquade, you might check with MRC (they're in England) to see if they might fabricate similar inlets for your S6 turbos. If I recall correctly, the inlet diameters on the S and RS turbos are slightly different, with RS being a bit larger (I recall placing my old inlets side-by-side with the RS inlets and they had different diameters. The benefit with the MRC inlets (other than that they look cool) is that you could then use the accordion connections to hook up to whatever airbox you wish.
    Senior Member Three Rings RSLRS71's Avatar
    Mar 03 2017
    18' SQ5 and WK2 SRT8 Jeep
    Castle Rock, CO
    NEED more POWER!!!! help a man out. lol
    2017 RSL RS7 (1 of 3 stateside)
    Mods:
    Current: APR Stage II w/ HF DPs and KW H.A.S kit , Rotiform 3 piece SPF 21x10.5 wheels, Tag Motorsports Side marker delete and Badge blackout, ...
    Next: looking to be the quickest RS7! ;)
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Not sold on it just yet even on RS turbos
    Maybe larger turbos than a RS might see something
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Jun 30 2016
    NNJ
    Curious to see these cut short for universal intake fitment. More flow certainly can't hurt regardless of turbos.
    Veteran Member Four Rings sciblades's Avatar
    Mar 20 2009
    North Salem/Palm Beach
    How much are the Mrc inlet?
    Sent from my SM-N950U using Tapatalk
    2016 RS7 Stinger VIP laser and radar, Unitronic Stage1+
    Gone
    2013 C7 S6- v1 and LI- Unitronic tuned]
    B8 S4
    06 a3 Full Votex Kit, Unitronic III, apr tbe, precision 750 FMIC, apr HPFP forge dvi, EVOMS cai, BSH gt3076r turbo kit, IE rods, sb stage IV, LSD, on meth
    Veteran Member Four Rings cobrario's Avatar
    Oct 28 2014
    2015 Q5 3.0T, 2019 Toyota Tundra CM Limited , 87 Buick Grand National
    Northern VA
    Quote Originally Posted by sciblades View Post
    Roughly $1200 w/shipping
    2018 Ara Blue RS3
    IG @cobrario_rs & @audivstheworld
    Mar 20 2009
    Lol that is ridiculously expensive
    Gone
    B8 S4
    Oct 28 2014
    Northern VA
    Yup
    2018 Ara Blue RS3
    Nov 22 2016
    Olympia, WA
    Although they are expensive, I recall them being about 700 British pounds, around $800 USD plus shipping.
    Oct 28 2014
    Northern VA
    Exchange rates will vary but the normal price is 750 pounds which currently is about $1075 plus shipping from the UK - either way I personally do not recommend them for a stock turbo car, I saw no demonstrable improvement in my car's track times.
    2018 Ara Blue RS3
    Nov 23 2017
    New Jersey
    I don’t see them for sale on SRM website ?
    Deactivated Four Rings
    Oct 22 2013
    New York
    Quote Originally Posted by AnesRS7 View Post
    Gotta email them or even call. Respond times vary they got back to me the next morning when I emailed.
    Nov 18 2014
    Jersey
    In for more info. Still waiting on something concrete.
    2018 Jeep GC Trackhawk
    2022 Audi SQ7
    2017 R8 TT. 1370whp.
    2007 Porsche 911 Turbo...Bolt On's
    Account Terminated Two Rings
    Feb 28 2018
    Florida
    Props to SRM for finding _the_ restriction on their TRUE intake system.
    Paving the way...
    Dec 11 2017
    67 Chevelle, 997 C4S, Yamaha Warrior, Ducati SuperSport
    Looks great ! 👍🏽 Wish it was available for an S6.
    Feb 24 2018
    2005 Ford Excursion 6.0L
    Las Vegas, NV
    Quote Originally Posted by bja72774 View Post
    It is available. $795 plus install. They installed it on my S6 few weeks back, very happy with it.
    2018 Mythos Black S6 | SRM Intake | APR Downpipes | Milltek Non-res Exhaust | Silly Rabbit E85 tune
    R.I.P.2015 S6 Glacier White | APR Stage 2
    IG: @outtie_lv
    Established Member Two Rings jinetics's Avatar
    Jan 18 2018
    GTR, GT4, RS7, E46 M3, Raptor
    Edgewater NJ
    Any news on when the rs7 tubes will be coming out on the market?
    Sep 07 2010
    Belgium
    Well i read on instagram that the tubes are compatable with both s and rs turbos (hmm tought inlet size was different :s)
    Mar 29 2014
    Hampshire, UK
    The inlets are different (but your changing them out) The turbo housings are the same, with a different core. At least that’s my understanding.
    In theory you could just fit the RS inlets to the stock S6 turbos
    Feb 14 2018
    2005 Yamaha R1
    Minneapolis
    How do these seal to the turbo side? Since the OEM ones go in the turbos with o rings.
    Veteran Member Three Rings DocTJ's Avatar
    Jul 29 2016
    PA
    Any new reviews/info on this?
    Im debating between this and Roc Euro for my S7.
    Also how difficult is the install on the SRM ?
    Thanks
    Prior: '16 A7 3.0T Prestige, '16 S7 Prestige, ‘17 S8 Plus, '18 Porsche Panamera Turbo S - E Hybrid
    CURRENT: '23 Nardo Gray RS5, Carbon Black Optics, '18 Q7 Prestige
    My S8 modified exhaust: https://www.audizine.com/forum/showt...Muffler-Delete
