Results 1 to 3 of 3
    Jul 01 2015
    Metro Detroit
    Power Seat not working
    So my seat will not move in any direction except forward, but even that is intermittent. Not a fuse because of that and passenger seat works fine. The lumbar controls work but the other two switches for the bottom and back don’t work except for forward. I’m assuming it just needs a new switch but I think it’s odd if all but one of the functions of the two switches failed at once. Any thoughts or experience with this?
    Matt, Metro-Detroit, Brilliant Red '04 S4
    I have timing tools for rent
    Senior Member Three Rings Pswish's Avatar
    Mar 25 2016
    2010 Suzuki VStrom 650
    Bay Area
    No experience with this happening but if it is a contact switch (metal on metal), you can try contact cleaner on it from radio shack/electronics store.
    Early 04 1.8T Dolphin Grey A4 (planning on selling), 165k miles and counting, often in bay area traffic, LED lows & HIDs fogs, ECS Snub mount, Electric systems specialist, Photographer, 2018 Q5 on order.
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Quote Originally Posted by mdhagan View Post
    Is there any sound at all when you press the switches in other directions (back or up/down)? If there's sound, it might be a mechanical issue with the gears. If there's no sound, it's electrical.
    If you can scan the car it would tell you whether there are any codes with the seat module or CCM.
    See if you can look under the seat (if it's raised enough for a bit of access) with a mirror and flashlight and examine the wiring. Some of it may be broken.
    If you can remove the side cover with the switches on both front seats, plug in the controls/switch from the passenger side to the driver's seat harness and see if the seat will move in all directions. Then you'd know it's the switch. Otherwise, it's the wiring or modules under the seat.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
