Results 1 to 10 of 10
    Active Member One Ring VAULTengineer's Avatar
    Mar 26 2018
    Audi RS4 b5
    Belgium
    Carbon Y pipe 034motorsport
    So, i bought this carbon Y-pipe. But after a closer inspection I saw that the inside of the pipe isn't smooth at all.
    Can this cause some unwanted effect on the airflow? The diameter is bigger than standard, so it should be better with the CAI that I also bought from 034 motorsport.
    But I seriously have my doubts now. your opinion on this?
    Veteran Member Three Rings rnagy86's Avatar
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    Are there pieces coming off on the inside? It looks weird.
    Veteran Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    Interesting. I would have thought they would have “finished” the inside with a clear or sanding considering the cost.
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    I don’t think turbulent flow past the MAF has a great effect on engine performance. In fact turbulent air-fuel mixtures burn faster, but I’m not an engine designer so I’m not sure what the effect is in combustion engines
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    I'm not an engineer either but the air has plenty of tie to smooth out before it hits the turbos. I wouldn't be concerned about it.
    Jul 07 2009
    Alberta, Canada
    Ahhhh...
    That sweet sweet 034 quality we've all come to expect/accept.
    - JVD
    Stage 6 B5 S4 - K&N Cabin Filter, PIAA Reverse Lamps, 4 Lug Conversion, Track Package, 4x 18" Pyle Subwoofers
    Oct 11 2016
    Connecticut
    Quote Originally Posted by JVD View Post
    Ahhhh...
    LOL
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    If I were you I would just resell it as the OEM RS4 Y-pipe is more than enough for even 850bhp :)
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by VAULTengineer View Post
    Yes, there will be more drag than an otherwise smooth surface. More pressure drop will push up the PR and result in less efficient operation of the system. The real question is whether the roughness is great enough to make a meaningful difference.
    Mar 26 2018
    Audi RS4 b5
    Belgium
    Thanks for the input! I think I’m going to use the stock Y-pipe. But I will test both Y-pipes on Hp, throttle response etc.. I will post the specs here. Must finish the engine first
