Results 1 to 23 of 23
    Jun 29 2015
    Danbury, CT
    Anyone have success with Headlight Restoration Kits?
    Hey Guys, so my 2010 is at about 71K miles, and the headlights are showing the signs. Up close they look pretty beat up from highway miles, and with the lights on you can see the cloudiness. So my questions is, has anyone used one of those headlight restoration kits, and if so, feel free to recommend one. They seem pretty easy, so if it works on our headlights, I would love to give it a go.
    Nov 28 2015
    Montreal, QC
    you need wet-sanding, good polishing and bare minimum a nano-coating or a professionally applied UV clear coat = Bottom line, it would cost you more than 500$ to get all these parts, pay a local bodyshop/detailer to do it :) but they do work.
    S4 B8.5 no track, just enjoying spirited driving.
    Apr 04 2012
    MSP
    I'd buy replacements if you can afford.
    Next best is polish them yourself with a proper buffer and product. I've had great success with that. A finishing polish is best. Wet sanding also works if you know what you're doing then finish with polish.
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Locating 1000 Grit or 2000 Grit wet sanding paper is done by going to an auto painting supply shops or on amazon where everything is found: https://www.amazon.com/3M-Wetordry-S.../dp/B0061JM4HG and Home depot: https://www.homedepot.com/p/3M-Wetor...3003/303173623
    Lot's of water and arm strength is needed. Finalized with Brasso and or another brand of metal polish. This works pretty well, but takes tons of time. https://www.mscdirect.com/browse/tnp...SABEgKTt_D_BwE
    However, having done that with other VAG cars, I found buying the lenses on ebay the easiest method. They cost around 150 bucks for the set.
    Veteran Member Three Rings TEB's Avatar
    Sep 19 2010
    '70 Cutlass, Yukon, MDX, Pilot
    Ponte Vedra Beach, FL
    A bit of a threadjack, but I did the sanding and buffing on my kids' Pilot. They look fantastic for a few months then need redone. I've just gotten in the habit of buffing them any time I'm doing detail work. What are the UV sealants that people are using? Do they work to maintain the looks for a long time?
    I really don't mind the buffing, but before I sand off the coating on any other lenses, I'd like to have a good sealer to use.
    2011 S4 6MT Ibis White|Panda Nappa|Titanium|Carbon|NAV|Sport Diff|B&O|H&R Sports|Unitronic 2+|RS5 brakes|034 RSB/Insert|10mm Spacers|Tints
    (Gone)2004 S4 6MT Silver|Black|Carbon|Bilstein|Hawk|Magnaflow|ECS
    (Gone)1998 A4 5MT Black|Black|Bilstein|A8/S4 Brakes|APR Exhaust|AWE DTS|Intrax Extreme|Flik|GIAC|Etc
    Jun 29 2015
    Danbury, CT
    Quote Originally Posted by A4 Centaur View Post
    Thanks for all this info. So if I went the route of new lenses, this means I would have to "bake" them to melt the glue holding the current lens and glue the new ones in? Not sure I would feel totally comfortable doing this myself after destroying a set of MKIV Jetta headlights back in the day.
    Jun 06 2016
    Florida
    Quote Originally Posted by amusante View Post
    Yes you need to bake them. I did them myself, it's extremely easy. I used some kind of silicon glue I bought at Auto Zone to seal the lenses, although the OEM glue just re-heated and sealed the new lense
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Replace lenses best and cheapest way.
    Plus a good time to ditch those amber side markers.
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    I had good luck with:
    McKee's 37 Headlight Kit
    Worked fairly well for just a drill attachment - and the protectant seems to hold up well. I will say they do have a newer "Coating" that is designed to hold up longer...
    Also note - the Headlights in my case were not fully hazed over - but just dull - but came back cleaner than ever
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Veteran Member Three Rings red4life5's Avatar
    Dec 29 2016
    2004 Audi S4 Avant
    Cleveland, OH
    I just re-did my headlights with the clear lenses swap. $120 for the lenses, $20 for the sealant, then I went $60 for the clear laminated so they won’t get destroyed again. If you have a $20 best gun the lenses come off easy and are easy to put back together; seriously. Everyone should do it
    2010 A4 S-Line Prestige
    2004 S4 Avant Greenwood Green
    2011 A3 K04
    2008 A3 -Sold
    2010 Audi A4 K04 -Sold
    Sep 19 2010
    Quote Originally Posted by red4life5 View Post
    Do you have a link to the lenses for sale? I did some searches, but no luck.
    Jul 07 2009
    Socal/IE
    Quote Originally Posted by TEB View Post
    EBay type in audi b8 headlight lenses or similar
    Veteran Member Four Rings Bruno_s4's Avatar
    Mar 12 2010
    Richmond Hill, Ontario
    I did the lens and reflector replacement last year. Very easy. So worth it.
    Sent from my Samsung S8+
    2010 Sprint Blue S4 DSG | Sport Diff | GIAC Stg 2 + TCU | S4Matty ported charger/throttle body | PLM | AWE Touring + Resonated DP | ECS Kohlefaser | H&R Clubsport RSS | Renn Motorsports RS-51 19 x 8.5 | Super Sports | Stoptech ST60 BBK | Endless RF650 | 034 X-Brace | CR-15 | 034 Rear Bar | 034 Rear Diff Inserts | ENLAES Spoiler | Driving Passions Diffuser| RS4 Grill | STVBEK Front Lip | Clear Corners |Philips Ultinon 6000k | G6 6500k LED Fog | FBSW | JL Audio 10W6v2 | 500/1v2 | LC2i
    Feb 23 2016
    Chicago
    On A Budget
    Oct 13 2009
    MN
    Aren't those kits meant for plastic lenses and ours are glass? Didn't think glass lenses have the cloudiness problem. Pitting sure but can that even be fixed with polish?
    2013 S4 - Glacier White - 6MT - Sport Diff - GIAC Stage 1 - Scorpion 2.5" Exhaust - Performance IE Intake - StopTech ST60
    Established Member Two Rings joe biker's Avatar
    Sep 11 2016
    vero beach,florida
    Are we talking plastic or glass ???
    Aug 17 2015
    California
    The B8 lenses are easy to remove with a heat gun. There are a few DIYs on here. You can find OEM replacements on eBay, from China, for about $100.
    Really you can't go wrong replacing the lenses.
    Oct 13 2009
    MN
    Quote Originally Posted by joe biker View Post
    Our lights are glass which is why the only way to repair them is with new lenses. Polishing is for plastic.
    Established Member Two Rings Tuneman7's Avatar
    Sep 07 2015
    New York, NY
    Quote Originally Posted by PopTart View Post
    On A Budget
    This doesn't really work all that well, it will clear the cloudiness to a certain extent. With the UV coating already stripped the cloudiness will come back in a few days if that.
    I would suggest replacing the headlamp or the lens if you can. Unfortunately the DIY kits will never hold up as well as the OEM UV coating from what I've read.
    I replaced the headlights on my Dad's 2006 Camry that had this issue, fortunately a good set of replacement headlamps were 100$ combined. I believe on B8/B8.5 S4's they are more in the realm of ~500 per headlight.
    Sep 19 2010
    Quote Originally Posted by CrownSeven View Post
    You sure about that? I believe they are all poly-carbonate.
    Jul 05 2016
    Ontario
    Try an off the shelf lens polish kit first. I’ve had moderate luck with these. Or you can just wet sand and use various grits of polish the exact same way you would fix clear coat. You have to be careful not to get the plastic too hot tho.. The more elbow grease you apply, the better the result. Doesn’t last though (regular maintenance is required) and it doesn’t cure heavy pitting.
    Oct 13 2009
    MN
    Always assumed they were glass - haven't found a source that said they are not, but who knows, I could be wrong.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I'd be very surprised if they were glass.
