Results 1 to 10 of 10
    Veteran Member Three Rings Shahek's Avatar
    Feb 14 2018
    Sunland/CA/US
    opinion on Advans
    Okay I know this has been asked before but just wanted some opinions on some Advan RZ's. I got my eye on a set that is 18x8 and the offset is 47mm. However, the bolt pattern is 5x100. I'm wondering If I use some 15mm adapters, you guys think it would look good? So ultimately the offset would be 32mm, if i'm doing this correctly.
    Thanks
    Feb 14 2018
    Sunland/CA/US
    Bummp!
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Started a thread to ask if wheels would look good? You know what the wheels look like, and you know what your car looks like. I think you can handle this one.
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    I think the question is more geared towards the offset/spacer combo.
    To answer your question, an 18x8 +47 with a 15mm spacer/adapter will give a final offset of 32. That will sit just inside the fenders. I’ll let you handle the looks part.
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Wheels look fine (thanks for the pics, they loaded great), but why not get a different brand that looks exactly the same with the correct bolt pattern and offset?
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Feb 14 2018
    Sunland/CA/US
    Quote Originally Posted by CELison View Post
    thanks man.
    Feb 14 2018
    Sunland/CA/US
    Quote Originally Posted by CJ_ View Post
    yes, exactly. Thank you that's what I wanted to confirm. Just wanted to make sure and get a little bit of a better idea of the stance.
    cheers!
    Feb 14 2018
    Sunland/CA/US
    Quote Originally Posted by Timtheguru View Post
    Sorry no pics, just looking around and came across this set. I'm still looking and might go with another option. Thanks anyway.
    Dec 30 2009
    Quote Originally Posted by Shahek View Post
    Used I'm guessing? Get new for cheap wheels, unless you're getting used original equipment Audi wheels.. those are acceptable used. I find that aftermarket wheels are often bent, and are more pain than they are worth, unless they were free and you refinish wheels for a living.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Feb 14 2018
    Sunland/CA/US
    I hear you, actually went and took a look at the wheels one has a bend. Seller said not a problem, but not worth dealing with it. I appreciate the advice.
