Results 1 to 16 of 16
    Senior Member Two Rings Krmass25's Avatar
    Aug 18 2013
    AMERICA
    Post Odometer reads L3 4-5 and no milage reading... Anyone ever see this before?
    So my odometer doesn't read milage. It reads a code: L3 4-5
    I can't find any way to reset this and fix it. Had to make up a milage when getting inspected. Now the problem is getting a little annoying. .
    Anyone have any experience with this?
    Account Terminated Four Rings
    Apr 30 2017
    Personally only saw something similar to that when installing an RS4 cluster into my car, prior to it being cloned from my factory cluster.
    Sep 02 2008
    Boonies VA
    Did you swap in a color cluster? I see your date says 2004 and the airbag light is on.
    Veteran Member Four Rings yxri's Avatar
    Dec 27 2016
    Ford Lighting
    Ohio
    Sweet mileage. L3 4-5 seems like pretty low miles
    Aug 18 2013
    AMERICA
    The cluster was functioning perfect for years.
    There was a motor swap and I don't know if this began when that happened. Only noticed when inspected and couldn't click anything to pull it up. I had no idea this was just supposed to read the milage and never change. This L3 business is bizarre
    Aug 18 2013
    AMERICA
    The date reset because I disconnected the battery while working on the engine bay and the airbag light is due to the s4 interior swap with the passenger seat guts were not swapped and that is a project in itself. .
    Established Member Two Rings charmar's Avatar
    May 29 2017
    Northern PA
    Was the ECU replaced when the motor was swapped? If it's necessary to clone a new cluster (so it is recognized by the ECU) when installing it, wouldn't the reverse also be true? Meaning, if the ECU was replaced, it might need to be coded to recognize the existing cluster. Just thinking out loud....
    Sent from my XT1575 using Tapatalk
    Aug 18 2013
    AMERICA
    That is a good question ...
    I didn't think my ECU was changed because it is APR tuned and would have had to have been swapped and I'm pretty sure the motor assembly was swapped but not the computer. the gauges were working fine before and still do. This seems to me like a coding issue honestly. I bet a dealership would know...
    Aug 18 2013
    AMERICA
    Post
    It is not easy finding any information about this on the web.
    From what I've found the issue is usually related to key programming which I had done and I am not 100% sure if this started then but it very well could have. No one else has touched the car.
    If it was the key guy he will be getting a call! Not tackling this issue alone when someone else has caused it.
    Mar 24 2013
    Oakdale, CT
    The dealership might be your best bet.
    -Adam
    Dec 27 2016
    Ford Lighting
    Ohio
    The dealership might me your best bet.
    Be* : )
    I would also suggest you go to the dealership or ask Audi of America here on the forums.
    Dec 03 2016
    nowhere
    Quote Originally Posted by yxri View Post
    Be* : )
    Ask AoA?? Really...then I got a whole lot of questions for them.
    HEAR
    APR stage 2
    Aug 18 2013
    AMERICA
    ask audi of america
    Veteran Member Four Rings tloft4's Avatar
    May 15 2016
    Lock Haven, PA
    i spent 4-5 hours on hold with microsoft before, cant be that hard =p
    May 29 2017
    Northern PA
    OP, did you ever get this issue resolved?
    Aug 27 2023
    B7 DMT S4, 2003 20th AE GTI, 2003 2500HD Silverado
    Toledo, Ohio
    I am also wondering if this was resolved as I just bought a B7 DTM S4 that has the same issue. Does not really affect anything but is definitely bugging me!
