Results 1 to 29 of 29
    Veteran Member Four Rings GO-GOTEKNO's Avatar
    Nov 06 2007
    B5 S4
    Houston
    2001.5 3L GT28 Avant
    This is a no expense spared build. Car is 2001.5 Avant in ultra rare silver it is currently at 150,xxx miles. Engine bay is sprayed nogaro and was planning full respray and addition of rs4 rear bumper which I will include. Car is currently on break in tune. I need to pay my lawyer after my divorce so the car may have to go. Im open to serious offers. Everything has been replaced minus the AC compressor.
    MOTOR
    BF updated Block
    Polished 3L crank
    ARP Studs
    Calico Rod Bearings
    Wiseco 82mm pistons
    Pauter Rods
    Rockcandy billet girdle
    JHM Metal Water Pump
    JHM fan delete blockoff plate
    Autospeed GT28rs kit
    Updated 11 fin billet rotors
    Tial 38mm wastegates to open dump
    Silly Rabbit Enlarged plenum RS4 intake manifold
    Silly Rabbit V3 intercoolers
    Rs4 throttle body
    THE-Tuner Metal TBB
    AGM-Bipipes
    Darkside 4bar Map Sensor
    Integrated Engineering SAI block off
    Integrated Engineering fuel rails
    1000cc injectors
    -6AN fuel line
    2.8 heads w\ polished intake runners
    Supertech valves
    Supertech ti valve springs
    034 intake
    4in AEM dry flow intake
    Reisu 95mm intake tube
    034 RS4 Carbon Y Pipe
    034 intake
    034 big bore intake hoses
    034 breather hose kit
    034 Coil Conversion
    034 3.5in exhaust
    044 in-tank fuel pump
    Fluidampr
    CSF Performance Aluminum Radiator
    SPAL 16in EFK
    HANDELING & STOPPING
    17z Brembo calipers
    Drilled rotors
    H&R/billstein Spring and shock combo
    ECS Coil conversion kit front
    034 Race motor mounts
    034 race transmission mounts
    Apikol Rear Diff mount
    Transmission
    JHM Trio
    Southbend SS Stage 4
    USP stainless clutch line
    USP Metal slave cylinder conversion
    EXTERIOR
    OEM RS4 Front bumper
    OEM RS4 Grill
    18x8 DTM Kreuz
    May 20 2010
    No idea how much you owe, but if you've had a job that let you accumulate a 401k or similar, you could take out a loan to help cover your fees. Then you could hang onto the car.
    Not the best advice, but divorcing sucks ass.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Ditto on the divorce. Hopefully you can keep the car because there is a very slim chance you won't get anywhere CLOSE to what you have in this beast.
    Dibs on THE Tuner stuff if there's a partout ��
    Veteran Member Four Rings ActiveMonkey's Avatar
    Jan 27 2006
    C7.5 A6 3.0T Prestige
    Orange County CA
    beautiful looking car. GLWS
    Current: 2016 Audi A6 3.0t Stage 2+
    Old: 2000 Audi S4 Stage 3 - SOLD | 2000 Audi S4 Stage 3 - Deceased | 2002 Audi S4 Avant - SOLD | 2000 Audi S4 - SOLD | 2003 Audi A4 - SOLD | 2001 Audi A4 Quattro - Deceased | 1998.5 Audi A4 Quattro 5MT - SOLD
    Jan 01 2018
    utah
    The real question is. Did this car cause the divorce??
    Nov 06 2007
    B5 S4
    Houston
    Why would you ever marry someone that told you what to do with your money?
    Jan 01 2018
    utah
    I don't quite know. Side note. Do you have issues with ground clearance and the exhaust
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by GO-GOTEKNO View Post
    Because otherwise my wife would be living in a tent but would have about 1500 Louis Vuitton purses
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Jan 27 2006
    Orange County CA
    Sex.... yep, enough said.
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Awesome ride! Sad to see you post it up for sale.
    Nov 06 2007
    B5 S4
    Houston
    Quote Originally Posted by travis_w View Post
    It clears fine have only scraped once.
    Jan 01 2018
    utah
    What would you seriously take for the the car though.
    Veteran Member Three Rings 1ScientisT's Avatar
    Sep 30 2009
    Cleveland, OH
    Where did you source drilled rotors for the 17z brakes?
    Aug 08 2007
    Portland OR
    I honestly don’t even know what to offer....That’s everything someone looks for when buying a B5 S4! GLWS
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    Dam man, sad to see this for sale add. I was hoping to see it's full potential.
    Nov 06 2007
    B5 S4
    Houston
    Will include b7 recaros if offer is reasonable.
    Dec 08 2017
    Chicago
    how much
    Nov 06 2007
    B5 S4
    Houston
    [QUOTE=Damian_H1;13049980]how much[/
    Shoot me a PM
    Veteran Member Four Rings vailshred's Avatar
    Aug 20 2011
    Arizona/Colorado
    Pm'd
    Nov 06 2007
    B5 S4
    Houston
    Now officially for sale
    Mar 26 2018
    los angeles
    Asking price?
    Veteran Member Four Rings AudiForeman's Avatar
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    He said on fb any offer over 16k gets it
    Boosted.Tuned.Cooled
    Aug 24 2014
    Newport Beach, CA
    Really bummed about the circumstances. This looks like one of the best built cars in terms of specs, someone can buy a turn-key full build that would cost triple the ask to replicate. GLWS.
    2024 M3 Comp xDrive
    Established Member Two Rings billbB7's Avatar
    Apr 16 2014
    B5 S4
    MA
    Whoever gets this for 16k is taking it at a steal. Tough situation for sure, but it should go extremely quick at that price
    B5 S4 6MT: stage 3
    Past: B8.5 S4 6MT // B7 A4 2.0t 6MT
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    Please disregard the 16k$ comment! I have criss crossed two different cars. My mistake.
    Apr 16 2014
    B5 S4
    MA
    Ah, I should have questioned it. That seemed ridiculously low
    B5 S4 6MT: stage 3
    Nov 06 2007
    B5 S4
    Houston
    Drove it today , going to be harder to sell than I had anticipated 😢
    Nov 06 2007
    B5 S4
    Houston
    SOLD
    Veteran Member Three Rings kingofqueenz788's Avatar
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    Glad to see u sold it gl with everything bud
