Results 1 to 21 of 21
    Established Member Two Rings StefenJ's Avatar
    Dec 30 2015
    Passat S4
    Kvammen
    Gasspedal low signal
    Hello
    After doing a engine swapp my gass pedal suddenly wont work, here is the code im getting. Worked fine before the swapp.
    18041 - Accelerator Posision sensor 2 (G185)
    Signal too Low
    Going to the junkyard today to get a new one but i have a feeling it wont help.
    Aug 31 2014
    2002 stage 3 a6 6MT 2004 cavalier
    Charlotte/Roanoke
    It won't help. I had the same problem after doing a 6 speed swap. Was told I had to use one from a manual car but that's not true. Check your map and maf sensors along witb the plug for the throttle body. After that do a throttle body adaptation and see where you stand
    Sent from my SM-G930V using Audizine mobile app
    Apr 07 2011
    Home of the mighty beaver
    buy vagcom. read measureing block, press pedal up and down, view results.... Could just be a bad wire/connector or yes, bad pedal. Pin check from ECU to pedal connector for continuity. If good, then pedal, if bad, then obviously you have work to do there.
    dont randomly change parts without doing at least a little bit of diagnostics.
    Dec 30 2015
    Passat S4
    Kvammen
    ok...
    Have tested pedal with vagcom, after clearing fault code i get reading in like 0,5sec then it reads 0.
    After letting the car stand still with battery off it suddenly worken in about 1 min before the fault code appeared again.
    Have pin checked from connector (not ecu connector cause there are so small wiers) to the pedal, there are good connection there.
    But i did nor get readings when moving the pedal (not shure if iv done it the correct way but also not shure what signal to expect).
    Will do the throttle body alignment when i have the vagcom again.
    Aug 31 2014
    Charlotte/Roanoke
    Recheck your Maf map and throttle body connections they all matter to the pedal operation
    Dec 30 2015
    Passat S4
    Kvammen
    Will do!
    Aug 31 2014
    Charlotte/Roanoke
    Also I believe you can do an alignment without vag com something about turn key on depress pedal to floor and release and leave key on for 2 minutes but if you try it look it up to get exact procedure
    Dec 30 2015
    Passat S4
    Kvammen
    Thx will do!
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    Quote Originally Posted by Robsa6 View Post
    NO NO NO-----DONOT touch anything but the key---leave the key in the ON position(auto NOT running) for 20minutes then turn the auto off.......
    Aug 31 2014
    Charlotte/Roanoke
    Apr 07 2011
    that doesnt do shit for TBA. and its a waste of time.
    Aug 31 2014
    Charlotte/Roanoke
    So the clicking I hear jist like I do when I do the vcds isint the same huh? Sure sounds like it to me...
    Apr 07 2011
    Its not a TBA. This is an old myth from 20 years ago. The only proper TBA is one initiated from the basic settings.
    Aug 31 2014
    Charlotte/Roanoke
    That's just not correct but I'm sure you know more than I do so im not gonna go back and forth about it but I do know that when I had a tb fault and had to keep unplugging it I could go thru the process (more than a few times a day for a while) and it would reset it. In fact that is the whole reason I bought a vcds cable because everyone said no it doesn't work yada yada and when I got the cable in hand i tested the method and guess what? It showed me a brand new tb that id "adapted" with the key and the pedal that had 0 errors and been thru 8 adaptation steps so im gonna go with it does work
    Apr 08 2013
    Connecticut
    Per AUDI-
    [IMG][/IMG]
    Aug 31 2014
    Charlotte/Roanoke
    Nice
    Apr 07 2011
    a very old thread from long ago revealed that adaption values were not updated with the ignition key method. despite what the documentation might have said.
    ill leave it at that.
    Apr 08 2013
    Connecticut
    Quote Originally Posted by S4James View Post
    I was not aware of that---thanks for sharing....
    Dec 30 2015
    Passat S4
    Kvammen
    Thx for clearing that upp :)0
    Apr 07 2011
    ya i would take that with a grain of salt, it was a long time ago and far smarter people than I came to these conclusions so I never verified it for myself.
    but i will say that my vw master tech would audibly snort at me if I suggested the hood/ignition key method.
    Dec 30 2015
    Passat S4
    Kvammen
    Have been trying with a new sensor for the pedal today with no luck, but sfter trying many times i got some codes of the throttle bodie, im starting to think thats were my problem is.
