We took the unit apart to see if the graphite rotating assembly had cracked or shattered but that was fully intact. We then took a look at what causes the pump to stop in the first place once the doors are locked/unlocked. We found there is a white cylinder looking thing on top of the circuit board that reacts to pressure and vacuum. Once there is enough pressure or vacuum resistance, the unit should turn off. This is facilitated by this white cylinder. It has a diaphragm inside that moves a block which in turn moves a metal contact back and forth. This metal contact, when it touches another metal contact, is what tells the pump that the doors are locked/unlocked based on the vacuum/pressure resistance in the line and stops the pump from running.
Please use this information at your own risk.
To stop your pump from running until it times out, cut the below tab off the unit and slide the door out of the way.
Then take a pair of needle nose pliers and bend these two contacts in towards the center metal contact. This should shorten the amount of distance the diaphragm needs to travel to turn the unit off. To test, cover the holes with your fingers to see if the pump continues to run. You can leave the little trap door off until you find the sweet spot of when the unit will work properly. I had to try 3 times before I found the right distance. If you find that after you get the unit working with just your fingers and you hook up the pump to the system and it keeps running, you most likely have a leak in your system somewhere which you will have to find and plug.
Doug
