    Jun 11 2011
    Question Headlight not working - Help please!
    Passenger side. Swapped to a new bulb that works but still no light output.
    What else could it be? Greatly appreciated for your help.
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    A defective ballast may be the cause. Run a VCDS scan to see if any errors are presented, and also check fuses. And let us know what you find!
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Feb 11 2018
    London UK
    Yea I had this on mine one dealer wanted to charge me £700 for new headlight another dealer replaced the dipped ballast and it worked and still is. You can even do it yourself and buy a new one for cheap online. It's a easy DIY.
    Sent from my SM-G950F using Tapatalk
    Jan 21 2018
    Likely it's the ignitor. I had that problem one time. Fortunately I was covered under warranty so they swapped it out for me.
    Jun 11 2011
    It ended up being the ballast. Thanks for the help guys. Easy little DIY.
    Ended up upgrading the bulbs to Phillips X-tremeVision thinking it was the bulb. Nice and bright now.
