Originally Posted by
mikey7182
Thanks for the reply. I think my main concern is that I live in Phoenix, and the summers absolutely tax everything from the alt to the ac compressor. I’ll also be around 2,500w, the bulk of which will be class D, but I wasn’t sure how the factory electrical would hold up to that additional draw during 110 degree days. One idea was just adding onto my factory wiring with 1/0 instead of pulling and replacing everything. The pics of the factory charging wire that I’ve found online looks more like a harness or bundle of several cables, and most of them look to be at least 4awg but it’s hard to tell for sure. But if I leave all those intact and make an additional 1/0 run from the alt to the battery post, the post to the actual battery, and then my grounds, I think I should be ok. I mainly didn’t want to run into anything weird or out of the ordinary that might get compromised by adding new cabling (like having to scan in new battery serial numbers so the car knows to charge it appropriately, etc). I haven’t spent a ton of time working on this car myself like I have others in the past and don’t want to make an expensive mistake.
You'll be fine. Try running your stuff off the stock alternator and wiring first... If you notice dips, then run the secondary/replacement cable from alternator. I don't know if you will be able to get 1/0 to fit, but maybe 2 4ga.
I have 1/0 to my distribution blocks in the trunk from the battery and ground (I used a big bolt in the spare tire well area). The runs are so short, it does pretty well.
Also the car is fine if you unplug the battery completely. You just might have to set the clock and reset the windows for auto roll up/down again. Just be careful if you do decide to open up that bundle. I'm pretty sure the cable goes outside the car from the spare tire well.
There's a lot of space in the cable trays inside the car, but I also don't know if it's good to subject any of it to interference from the power cable. It's likely the reason why the main line from the alternator is ran outside.
Sent from my MI MIX using Tapatalk
