Results 1 to 8 of 8
    Jan 24 2012
    Tucson AZ
    2013 S6 CEL Codes - NOT a blown turbo :)
    Got a CEL two days ago and car is in the independent shop today. Just purchased the car a month ago, and fortunately also purchased an extended warranty.
    During the PPI they noted the P14AB code (exhaust flap valve) which was intermittent. Cleared, didn't think anything of it.
    Now, the car has the
    P14AB code
    and the
    P0491/P0492 codes - Secondary air injection bank 1/2. I believe this is causing the CEL. Independent is calling the dealer to see what to do next.
    Anyone have any experience with these? S4 forums noted carbon buildup issue, although I have not heard of this in S6.
    I was literally just about to purchase EPL tune too - glad it's not blown turbos and also glad that I didn't do anything (yet) to void warranty
    Mar 17 2017
    Redondo Beach, CA
    Have them check your ECU software version, if it's 0007 or older, then it could be this TSB, fix is to replace secondary air pump motor and update ECU to version >0008.
    DTC is different from a regular P0 Trouble Code.
    TSB 2036558:
    One of the following DTCs is stored in the engine control module (ECM), J623 (address word 01):
    • DTC P244000 (Secondary air injection system switching valve stuck open - Bank 1)
    • DTC P244200 (Secondary air injection system switching valve stuck open - Bank 2)
    Technical Background
    ECM software adjustment of the secondary air pump motor (V101) runtime during the diagnosis phase.
    Production Solution
    ECM software update.
    Service
    Replace the secondary air pump motor (V101) and update the ECM software.
    SVM Update Instructions
    1. Follow all instructions in TSB 2011732: 00 Software Version Management (SVM), operating instructions.
    2. Update the ECM software (J623) using the SVM action code as listed in the table below, if necessary
    2013 Phantom Black S7 | Bang & Olufsen | Driver Assistance | Night Vision | HUD | Comfort seats | LED headlights | 20" 5-arm-rotor design | Carbon atlas inlays | Cold weather package | EPL Stage 1
    Jun 18 2017
    10512 Hunter Trl/Illinois/
    Quote Originally Posted by hanyoung View Post
    P14AB code
    and the
    Are you using the stock intake system?
    Jan 24 2012
    Tucson AZ
    Yes. I will have them check tsb
    - - - Updated - - -
    You guys are way better than any dealer!
    - - - Updated - - -
    Jan 24 2012
    Tucson AZ
    weird - dealer did replace pump - one week later same CEL with code. Will bring back and have them recheck!
    Jan 24 2012
    Tucson AZ
    So just talked to shop - they think it is a secondary cylinder issue as the pump is working fine. Aargh... may need to open her up to do a cleaning. Anyone had any issues with a similar problem? I know that carbon buildup could be an issue, but have yet to hear of anyone developing codes for it. My S6 has 64K miles, just bought it less than 500 miles ago! Weird thing is that car was serviced at dealer all the time - and no history of any of this on the sheet.
    Oct 12 2009
    Ducati 959
    PNW
    Did the dealer get you sorted, hanyoung?
    I'm throwing P0491/P0492 on my 2013 S6 as well, with similar mileage (79k).
    I get the loud "jet engine" sound on start up for ~5-10 seconds. Clear codes, and they come back on every cold startup (along with the noise).
    Likely unrelated, but I also have the terrible sputtering/misfire feel at low RPM's (1200-1500).
    Cheers!
    Jan 24 2012
    Tucson AZ
    Sorry about the delay! Codes cleared after dealer checked electrical connection of pump. So far no more codes or problems! I do occasionally hear a rattle on acceleration in cold weather. Not sure what that is - maybe pcv but no codes. I’m also loving epl beta tune.
