Results 1 to 4 of 4
    Oct 16 2014
    Pic of hoses in back of engine?
    Does someone have a clear pic of how the various hoses in the back of the engine line up? I took off the manifold over the weekend- was able to put it back together but some of the hoses feel pulled bc i don't think i've arranged them quite right.
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    If your OCD is tingling with those hoses, it's quite normal. Audi designed them quite funky. I remember when I had the manifold off the first time I had the same feeling. Just make sure they are not pinched and that's that.
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Established Member Two Rings RichardG's Avatar
    Feb 14 2004
    2023 RS6. 2019 RS5 Coupe, 2018 A5 SB
    Phoenix AZ Area
    Quote Originally Posted by b57 View Post
    Pics I took before I did the first carbon clean. Good luck, even with pictures it was hard to get them back to perfect.
    2023 RS6 Mythos Black | PPF | IE Intake | Cete Active Suspension Control | Cete AVC | 2019 RS5 Coupe Nardo Grey | XPEL PPF | Eventuri | Milltek Non-Res, AVC | BCForged 20x10 | ABT HAS | 034 Adj Upper Control Arms, Trans Mount | ECS Front Strut Brace| IG: @rs4play
    SOLD
    2008 RS4 Phantom Black | Stasis MS | 034 Density adj. Upper Control Arms | StopTech Pads and Rotors | H&R Spacers | ECS Rear Diff Mount | Magnaflow Cat-back | B8.5 Flat Bottom Steering Wheel
    Oct 16 2014
    3rd pic is exactly what i needed. thank you sir
