    Veteran Member Three Rings AvusPdx's Avatar
    Jan 17 2015
    Portland, OR
    Avant springs for the rear (H&R coil overs) to fix sagging issue
    I tried searching for anyone putting avant springs in the rear with the H&R coilover set up. I thought I heard that it can raise the rear a bit and the springs are stiffer. I'm at max height in the rear, and my wheel/tires tuck. Has anyone replaced the rear springs for the avant ones? How did your ride quality change? Stiffer spring in the rear would help the car rotate a little bit more?
    Current - Audi B8.5 S4 2013, Mercedes Benz GLE350 2016, Volvo XC60 T5 2015
    Mods - H&R RSS Clubsport, APR stage 2 + pulley, Roc Euro intake, AWE Touring 90mm, ECS RS4 Gloss Black Grill, VMR V705 19x8.5 matte black, Blizzak LM32 225/40/19 (winter) OEM Q5 Peelers 20x8.5 et33, Dunlop Sportmaxx 245/35/20, EBC Slotted/Drilled rotors F/R, EBC redstuff brake pads, Motul RBF 600 brake fluid, Enlaes rear CF spoiler, LED interior light swap, LED fogs, H&R rear sways,
    Jan 17 2015
    Portland, OR
    *crickets
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    What are the spring rates on the avant springs vs the sedans that are 450? If I remember right.
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    Oct 14 2012
    Empty...for now...
    SE PA
    I'm curious about this as well. Same issue with my H&R Street Performance coilovers - I have the rears spun all the way up and I'm not tucking, but the tires are about even with the fenders and I would like to raise them up a bit more to elimiante the "reverse rake" illusion that is happening.
    SOLD 2015 Daytona Gray S4
    Jan 17 2015
    Portland, OR
    I posted on the KW spring spacers post if it works with the H&R coils. It seems to work with Bilstein coils so far. This would be the easiest fix not messing with the avant springs not matching up to the dampers.
