    Veteran Member Four Rings AUDIFREAK23's Avatar
    Apr 03 2008
    NH
    H&R ETS lowering moduel question
    Hey guys,
    So Ive had my lowering mod in for a couple months now. I noticed the other day that passenger side is almost an inch lower then the drivers side regardless of what mode im in. I want to see if anyone has had this problem and been able to correct it. Im OCD and its driving me crazy! haha
    2001 S4-->2004 A4 Ultrasport-->2007 A4 3.2L Sline-->2010 A5 3.2L Sline-->2014 S5-->2014 S6-->2016 SQ5-->2016 A7
    Mar 03 2014
    2014 Audi S7, 2010 Audi S5 4.2 manual, 2016 ZX-14R
    Olympia, WA
    While I do not have the module, I would test to see if it is uneven without the module. If so, then you need to re-calibrate your air suspension with vagcom.
    2014 S7 Prestige, SRM Long Tubes, AWE Touring Exhaust, DS1 Stage 2, Vertini RF1.3 20x10.5 with 295/30/20
    2010 S5 4.2L 6MT, Armytrix valvetronic, ECS BBK F&R, JHM tune and short throw, Matte Black Wrap
    Apr 03 2008
    NH
    Quote Originally Posted by JGood View Post
    I can re-calibrate with the module in as well correct? How do I do the re-calibrate with the Vagcom
    Mar 03 2014
    Olympia, WA
    I am not familiar with the options on the module, but you can adjust your ride height on all four corners via vagcom, check this out and adjust as necessary https://www.audizine.com/forum/showt...light=lowering
    Veteran Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    This sort of thing happens from time to time and has been reported by a bunch of folks, even without any module. You can try resetting it to stock height with the module and then re-lowering (quickest option). An alternative would be to simply go in the MMI and 'raise' the vehicle and then lower it back down and it should be even again. Make sure you're on a level surface whenever you do any of this.
    2016 S6, mythos black, RS7 turbos, MRC inlets |Akrapovic exhaust| AMS downpipes and intercooler |Eventuri intake| Loba HPFPs |Tial wastegates| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights, OEM Euro tails |Sound: Navtv Zen-v preamp, Helix DSP Ultra, JL HD900/5 driving JL10W3 sub and Hybrid Audio speakers.
