Results 1 to 4 of 4
    Senior Member Two Rings mp3driver's Avatar
    Jul 31 2009
    2019 Nissan Kicks <--its the wifes!
    Tulsa / Oklahoma
    K-Sport Coil Overs
    Is there anyone else that has any experience with the Kontrol Pro coil overs on the B5 S4?
    I installed these last year and the car drives great most of the time. I am trying to figure out the rear more than anything. So in the rear the spring is the ride height period. I think im fighting dampening more than spring issues, but what happens is when I hit a bump in the road ( roads here are horrible ) if its a large bump, the car gets jar'd pretty hard. No through a few dips its has pretty good control and no issues. I have spoken to ksport and they want me to zip tie the shock which with the Kontrol Pro and the audi this is very difficult to due cause you cannot see the shock when its in the car due to the mounting on the rear. When it hits its almost like you bottomed out the shock but I've checked and checked and the rear has much more movement ant that shouldn't happen. I forgot this detail, The car is at stock height pretty much.. I think I lowered it maybe 3/4" ... Now I have raised the rear up by 1/2" and the bump is less but still Jars pretty hard. So im gonna take the dampening approach which after all of this being done. I am starting to think its a little high. we are 27 clicks hard out of 36. so im gonna reduce this to around the 20 mark and see what we get. just curious if anyone else has ran the Ksport coils on their B5 S4
    As you can see in the pics the car isn't really that low.
    Thanks for reading.
    2001.5 S4
    6MT Swapped
    Still my Favorite Car!
    May 20 2012
    San Jose
    These?
    http://ksportusa.com/products/coilovers/kontrol-pro/
    Most damping adjustable shocks only adjust rebound damping, but these do both with one adjuster. The adjuster typically only affects low speed damping (slow shock movement, small bumps). From your description it sounds like you have too much high speed compression damping. You may not be able to do anything about that short of having the shocks revalved. But try backing the adjuster fully out and see how it goes.
    Jul 31 2009
    Tulsa / Oklahoma
    Quote Originally Posted by oppositelock View Post
    These?
    Most damping adjustable shocks only adjust rebound damping, but these do both with one adjuster. The adjuster typically only affects low speed damping (slow shock movement, small bumps). From your description it sounds like you have too much high speed compression damping. You may not be able to do anything about that short of having the shocks revolved. But try backing the adjuster fully out and see how it goes.
    Yes,,, the adjuster is a combo adjuster. I have talked to Ksport and they said they changed the shock style the week after mine shipped. (typical) im going to try the recommended settings they have advised me to try. Thanks for the input.. Ill post back with my results. I'll likely have time tomorrow evening to tear them down and make the changes and test them out.
    2001.5 S4
    6MT Swapped
    Jul 31 2009
    Tulsa / Oklahoma
    okay, Tonight I pulled the coil overs off of the rear. I reduced dampening from 27 to 20 click in from soft to hard. Removed a little spring.. The car rides almost perfect. Felt very smooth and stable and handled really good but not race car rigid, which in the end is what I am working towards. So at this point I am setup with 28 Clicks in on the front with no preload on the springs, and 20 in the rear. working well.
    2001.5 S4
    6MT Swapped
