Then I took a closer look and I saw this...
Someone took a file to it to widen the hole for more wide range fitment?
Is the misalighned pipe good for performance?
This one is just carelessness, pipe is probably going to fail or crack. Metal is cut about halfway through...
These weld gaps are found at the mounting points. Why? To accommodate for mounting nut clearance. It is this way because the pipe is wider while the flange is same size as stock.
I contacted JHM to ask what went wrong here. To make the long story short Jake stated there was nothing wrong and that’s how these come. Essentially this is what you will get if you put in the order.
As far as the return goes, I was given 1-2 weeks to see the money back and also, was denied a return shipping label for a reason that there was nothing wrong with the product. On the positive note I was told I will not be penalized a re stocking charge.
