Results 1 to 15 of 15
    Established Member Two Rings marto7's Avatar
    May 06 2017
    Sofia
    What fuel return rail for 1.8T BFB
    Hello.I have Audi A4 1.8T Quattro with BFB Engine.My fuel rail is without return line and i want to make it like B5 - With fuel pressure regulator and return line on Fuel rail.I know i need to change the filter but what rail i should use ? My stock FPR is 4bar and i need 4bar from 1.8T A4/A6 or passat but are all of 1.8T is compatible ? I have a list that i see the type of injectors that used in different 1.8T engines but are the EV6 (for example from AEB) is compatible with EV12 injectors (my car) ?
    Feb 17 2004
    Liberty Hill, TX
    you want to use the fuel rail from an AWM: 06B133681. Same injectors will fit as your current rail, only difference is the return line/FPR.
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    May 06 2017
    Sofia
    If its only this i hardly can find it here in Bulgaria.Here is my list with different injectors on 1.8t engines
    https://ibb.co/gMyLcH
    Jul 18 2011
    Norway
    Here is how I did it on a BFB engine
    https://www.audizine.com/forum/showt...em-into-B6-DIY
    May 06 2017
    Sofia
    Did you use AEB rail (stock ev6 injectors) on BFB engine ? I readed this article but i think you changed the engine head with AEB one.If AEB is compatible i can find
    And where are the FPR hose goes ? To the intake manifold ?
    Now i see you used injector spacers.I dont want to use spacers and for this is my topic.Why i need to buy spacers that are more expensive than rail, when it have Bolt-on rails for me.
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by marto7 View Post
    using the AEB rail on a BFB manifold will require spacers. You'll want to connect the FPR directly to the manifold, yes. I added a nipple where the AWM manifold has one, directly across from the FPR
    Jul 18 2011
    Norway
    The ecu on the B6 is designed/tuned to run static fuel pressure, so leave the vacum port on the fpr open.
    May 06 2017
    Sofia
    Quote Originally Posted by J_L View Post
    Are you sure to leace it open ? What is the difference if it open or connected to manifold ?
    Feb 17 2004
    Liberty Hill, TX
    open = run at static FPR pressure (4 bar)
    manifold = run at static pressure + manifold pressure (above atmospheric)
    May 06 2017
    Sofia
    Thanks good to know. I will leave it open. I found 1.8T APU rail.This will fit bolt on for me right ?
    Veteran Member Four Rings Bische's Avatar
    Jun 03 2009
    2002 Big Block Avant
    Sweden, north
    1.8t AEB rail, comes with a 4bar FPR also
    May 06 2017
    Sofia
    Yes but for AEB rail i need injector spacers. I preffer bolt on solution.I found from APU. I think its bolt on but want some other opinions too.
    Can i trust this list, and if its with 4bar and EV12 injectors original i can install it directly:
    Jun 03 2009
    Sweden, north
    You don't need any spacers with the AEB rail mate
    May 06 2017
    Sofia
    But Matt Devo up there told that i need spacers for AEB rail on BFB manifold. I think because AEB comes with EV6 injectors and my BFB is with EV12 injectors.
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by Bische View Post
    you do need spacers between the rail and manifold when using a non-AEB stock manifold (or, at least you do with an AMB manifold; the AWM rail fits correctly)
