Results 1 to 14 of 14
    Veteran Member Three Rings snocat17's Avatar
    May 12 2017
    2016 S5 Cab, 2016 Mazda CX-5, 2012 Ford F-250
    Steel City, USA
    Broken Plastic around Fog Light on S5
    So I just got back from a week in the Caribbean, all rested and relaxed, and opened my garage door to find this:
    Anyone help on the best way to fix? Would it be covered by warranty? I have 1800 miles until my 50K is up.
    -Joe
    2016 S5 Cabriolet Prestige Glacier White Metallic w/ brown comfort seats and piano wire black wood trim. RED Brake calipers holding EBC RedStuff pads, APR Carbonio Intake, ECS carbon fiber back-pipe, VCDS cable
    Veteran Member Four Rings Sgibb16's Avatar
    Jul 02 2012
    2012 A5 & 2002 Passat Wagon
    Fredericksburg, VA
    Buy a new fog grille
    PN 8T0807682N01C
    https://genuineaudiparts.com/parts/2...&siteid=214407
    2012 A5 P+ | Sports Package | 6MT | 35% Tint
    REVO Stage II | AWE Quad Exhaust | 034 HFC | E-Codes | FK Silverline Coils | JHM Short Throw Shifter | Eurocode HFIC Pipe | Roc Euro Intake
    TR8 Intercooler | CTS Silicone Hose Kit & Turbo Outlet | CR-15 Strut Brace | Alu Kreuz | S-line Front & Rear Bumper Conversion
    Mar 18 2015
    2015 GL450
    IL
    Looks like a rock went through it, which wouldn’t be warranty. Depending on grill cost you could try insurance against your comprehensive. Might not be worth it depending on your deductible though.
    Sent from my iPhone using Tapatalk Pro
    2016 S5 6MT - Brilliant Black, P+, High Gloss Black, Sport Dif, B&O, Tech, Nappa
    Engine: GIAC Stage 2 & SC Pulley / ECS Carbon S-Flow Intake
    Suspension & Wheels: H&R Street Performance Coilovers / Vorsteiner VFF-103 (Carbon Graphite)
    Exhaust: AWE Touring
    Cosmetic: OEM RS5 Grill / PPF & CQuartz Finest Coating / 35% Pinnacle Tint
    Oct 09 2008
    Cut the rest out and put in brake ducts
    The Awesome™
    Veteran Member Three Rings Sazexa's Avatar
    Jul 15 2017
    Colorado
    I second what JoshDub said!
    But in all actuality, I think you can remove some of those fog lights from the front of the car. I was able to on my B8. Buy a new (or used) one on eBay, shouldn't run more than say $150 I'd assume. Or get RS-style aftermarket ones.
    May 12 2017
    Steel City, USA
    I didn't find anything on ebay. I found an Audi parts dealer that gave it to me for $260.
    How hard is it to change out the piece? I have a body shop here about 30 min away from my small town that will do it, just looking for info in case it is easy enough to do myself.
    -Joe
    Jul 02 2012
    Fredericksburg, VA
    Quote Originally Posted by snocat17 View Post
    It just pops out, there is a hole above the light. Pull from there.
    May 12 2017
    Steel City, USA
    Quote Originally Posted by Sgibb16 View Post
    Above the fog light?
    -Joe
    Jul 02 2012
    Fredericksburg, VA
    yes
    May 12 2017
    Steel City, USA
    yes
    Alright, cool. No need to take anything off? I might use a screw driver and play around with it tonight.
    -Joe
    Jul 02 2012
    Fredericksburg, VA
    No just pull it straight out. A hook tool something like this is the best thing to use.
    May 12 2017
    Steel City, USA
    Wow, can't believe how easy it was to change. Hardest part was verifying it was the correct part and waiting for it to get here.
    -Joe
    May 12 2017
    Steel City, USA
    Thanks for the help, this was definitely a big help.
    -Joe
    Jul 02 2012
    Fredericksburg, VA
    Glad it worked out
