Results 1 to 11 of 11
Thread: Maf issue
    Established Member Two Rings 2000Stg3S4's Avatar
    Jun 03 2015
    canada
    Maf issue
    How often do Hitachi mafs fail ? Car drives better with it unplugged means it's bad most likely ?
    Sent from my ONEPLUS A5010 using Audizine mobile app
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Means you most likely have a boost leak. Unmetered air gets into the system (post maf, pre TB) which the maf sensor is not accounting for. Once you unplug it, the car goes into open loop. Could be a bad maf, but most of the time it's a boost leak. Pressure testing is the only way to find out. Looking and wiggling hoses won't tell you anything unless the problem is glaringly obvious.
    Jun 03 2015
    canada
    Ive done a boost leak test already had 1 leak on the wastegate line but that was fixed. I didn't find any other leaks but I also notice that the issue is kinda sporadic (boost leak wouldn't be) so I'm suspecting could be the sensor or maybe even the wiring to it since it's converted to Hitachi
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    Just log the MAF... that’ll tell you if it’s bad.
    Jun 03 2015
    canada
    You mean like measuring blocks, it usually reads 3.5 g/s at idle, ive read it should be closer to 5
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    YES- Group- 3
    With a stock MAF setup you should see 200-210g/s at some 3000 RPM building to 240 to 270 g/s from 5000 to 7000 RPM
    The higher figures are typical for an aggressive Stage-II tune.
    Jun 03 2015
    canada
    I see 247 g/s , 2nd gear pull, does that mean it's reading quite low for a stage 3 awe ?
    Feb 21 2016
    2002 A6 2.7t manual swap
    Colorado
    Quote Originally Posted by 2000Stg3S4 View Post
    What's your altitude where you live and what's the ambient temp when you logged the data? Air density plays a huge role in MAF readings.
    Active Member Four Rings
    Nov 12 2013
    '01 S4 Tip '91 200 20VTQA, '01 A6 2.7TA, VW Rabbit GTI truck.
    SanHo, CA
    Yes, I know, tune up in a can is not the usual course of action here but this has straightened out the last coupla MAF codes I've had: https://www.amazon.com/CRC-05110-Mas...+cleaner+spray
    Oh yeah, and replacing the throttle boot.
    I would go so far as to suggest you clean the MAF whenever you change Air filters. Or something...
    Jun 03 2015
    canada
    Quote Originally Posted by brokenwrench View Post
    1100 feet above sea level, 5 c usually
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    You either have a boost leak or big vacuum leak. The car running worse is actually indicating the maf is working.
    It’s overcompensating for the extra unmetered air.
