Results 1 to 4 of 4
Thread: Will they work?
    Mar 26 2018
    Suwanee GA
    Will they work?
    I bought a set of 2018 SQ5 calipers and found out they don’t bolt up to our spindles. Anyone know if he b9 spindles work on our cars?
    2013 Audi S4 | Drive select | AWE Touring Exhaust | AWE Downpipes | APR Carbon Fiber Intake | TSW Mirabeau 2 piece wheels | Michelin Pilot 4S tires |
    Coming soon 2018 SQ5 sport 6piston calipers
    Apr 05 2016
    Portland, OR
    The B9 brakes work on our car if we shave down the hub a bit. Might be the same with the new SQ5 setup.
    That or you might need to swap things around similar to the Porsche Macan brakes. (Check out that post if you haven't)
    Geoff
    Mar 26 2018
    Suwanee GA
    Thanks for the quick response!!! Yeah the bottom bolt wouldn’t line up without modifying the spindle a little bit. It was almost hitting the rotor on the top portion and the pad seemed close to the center. Maybe the new SQ5 has a different style.
    Mar 26 2018
    Suwanee GA
    Here’s the caliper.
