Results 1 to 3 of 3
    Veteran Member Four Rings gqambitions's Avatar
    May 27 2015
    Atlanta,GA
    Set of 4 10mm Hubcentric Spacers
    Wondering if anyone has 4 10mm Hubcentric spacers for sale. Have searched the forums but cannot find a set of hubcentric ones for my rs5 Rotor wheels. Thanks for any help in advance.
    APR Sponsored
    Current- 2021 S6 Premium Plus on Arras red/ My build thread --> https://www.audizine.com/forum/showt...(Build-thread)
    Past-
    2018 B9 A4 (s line) Mythos Black metallic
    2008 VW Passat Wagon- Stage 1 Giac
    2010 B8 s5
    IG/TikTok/Youtube:@ikelifestyles
    Veteran Member Four Rings SLU_S5's Avatar
    Sep 06 2014
    Rochester, NY
    Just FYI, you’ll probably have 5mm of poke on the front wheels if you’re using a 10mm spacer with RS5 wheels. 10mm rear and 5mm front should be perfectly flush.
    2010 S5 Prestige 6MT: B.Black:
    APR: Intake // AWE: Touring + non-res DPs, S-Flo filter // CR-15: Brace // ECS: LWFW, Diff Mounts, SS Brake Lines // Eurocode: AK, Sways // JHM: Tune, Short Shifter // KW: H.A.S. // OEM+: B8.5 S-Line Competition+ Bumper, BO S5 Grille, Ecodes, RS5 BBK, 20" RS5 Rotors// SBC: Stg 2 Daily // 034 Motorsport: Intake Pipe, Trans & Motor Mounts, ACAs // Others...
    IG: @SLU_S5
    Veteran Member Four Rings Cloudg8's Avatar
    Oct 10 2012
    Jeep
    Chicago/IL/USA
    Quote Originally Posted by SLU_S5 View Post
    Even if lowered?
