Results 1 to 31 of 31
    Mar 12 2018
    Minnesota
    1 Year 30,000 Mile Review and Cost of my B7 Audi A4 2.0T
    Hello I want to make a thread regarding my review and my cost of owning my b7 a4 2.0t
    And i would also like to hear your experience with your b7 in the comments :)
    I bought this car late March of 2017 in Florida with 90k miles on the car.
    I moved back up to Minnesota and used my a4 as my daily driver for the last year and put a a little over 30,000 miles on it, alot of highway driving back and forth from MN to FL since i live in Mn and my family is in Tampa Florida (1650 Mile 1 way trip) and i make this trip a few times a year.
    I originally bought my b7 for $6500 and below is what has gone wrong and around what is costed to repair. Not including Oil changes that I have done every 5,000 miles with Mobil 1 0W40 full synthetic oil. Also car is bone stock besides new wheels, RS4 mesh grill and tinted windows.
    All Labor was done by a friend that worked in a VW Dealership repairing VW and Audi Cars for 20 years and is now retired and just works on cars as a hobby. So i may have paid less than if I would have taken my car to a shop.
    Coolant flange
    Part: $50
    Labor: $70
    Coil packs
    I have spent well over $300 with this problem because I kept replacing with shitty autozone/ Oreilys coils but I ordered a pack of OEM Coilpacks from audi for $170 and haven't had a coil blow since, so lesson learned ONLY BUY OEM PARTS.
    PCV Valve
    Part: $45
    Installed myself since very easy to install
    Timing Belt, and water pump
    Parts: $280
    Labor $400
    Front Lower and Upper Control Arms
    Parts: $380
    Labor: $400
    Fuel Filter
    Part: $40
    Installed myself
    Oil Cooler Seal/ Gasket & Oil Filter Housing Seal/ Gasket
    Parts: $35
    Labor: $180
    Total cost in repair on my after putting 30k miles and owning my a4 for a year not counting money wasted on garbage coils
    $2,020
    My A4 now has 122,000 miles on it and i love everything about my car and plan on keeping it untill it dies and then ill probally get a newer A4 or a v8 b6 or b7 S4
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    Ive been keeping a spread sheet Since I bought the car and it helps with keeping up maintenance
    you've been changing the CAM follower right?
    OEM parts FTW
    Sean
    The New
    B7---GIAC--BBS--DDM--JHM+S4Exhaust--StaSIS SS--034--AudiUP--USP--RedEBC--IE--DrakesVC#12--B7S4 Brakes--StopTech--GFB DV+--
    The Old
    B5---GIAC-K04--RACETEC--APR--DEPO--AUTOTECH--VMR--FORGE--034--H&R--BILSTEIN--FUJITA
    Mar 12 2018
    Minnesota
    Quote Originally Posted by thenofjboy View Post
    OEM parts FTW
    No I have not changed that yet should I ?
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    Quote Originally Posted by endolf View Post
    yes, like right now if you don't know what it looks like !
    dman, labor/part price make me realize that doing it all myself save me tons of money. For me it's a hobby, instead of playing video games, I go in my garage, put some music, jack the car, and open a beer.
    Feb 15 2016
    Cambridge,Ontario
    Holy crap you haven't done your cam follower ??? that's like the number one issue !!!
    Also you are in the sweet spot for the chain tensioner . If you have been reading the threads around here , the time is around 150K or when you hear noise under your rear timing cover.
    No stat yet ? that will be popping up on your list soon. You really should have done it with the rear flange is you had the system open and its a cheap part and pretty easy to change, you could have done it with the oil cooler seals too as its right there and made of the same cheap plastic the rear flange is made of.
    70 bucks to change a rear coolant flange ? at that price guys from this forum would line up all day long. its a PITA item.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Mar 12 2018
    Minnesota
    Quote Originally Posted by oVeRdOsE View Post
    Just ordered it and will be putting it in hopefully this weekend... I love working on my car but I don’t have a garage to work in and I don’t really wanna lay under a car when it’s -10 and snowing haha otherwise if it was summer I’d replace everything myself
    Mar 03 2018
    Richfield, WI
    What year is this car?
    Dont let everyone get you too excited about the cam follower. The guys on here got me all worried about mine so I pulled the cam follower out at 114k and it looked brand new (was the original). Lots of great info in here, but be cautious there are also a lot of alarmists..
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    170k here original timing chain and tensioner zero noises.
    Sent from my G3313 using Audizine mobile app
    Ivan
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Brad460 View Post
    its certainly not alarmist to check it..
    its good practice
    1976 Yamaha XS 360
    Mar 03 2018
    Richfield, WI
    its good practice
    Agreed...but this cam follower issue seems to be on older A4 (2.0 VWs and such). Older as in 2006. Mine is a 2008 and like I said it was nearly new looking after 114k.
    My guess..this cam follower issue is/was due to a cam lobe surface finish issue, not cam lobe hardness. From the damage I have seen it’s an adhesive type of wear...
    Aug 19 2013
    Miami
    Lol that's the first thing it should of been done before learning how to walk
    Ivan
    Mar 12 2018
    Minnesota
    Mines a 2005.5
    Feb 15 2016
    Cambridge,Ontario
    Mines a 2005.5
    Mine is too and was punched at 150K
    1976 Yamaha XS 360
    Veteran Member Four Rings tloft4's Avatar
    May 15 2016
    Lock Haven, PA
    Even if it's perfectly fine at 60/80/120k for the $100-150 a shop might charge to change it out, why not do it? Could be only 5% of cars that have that problem by then, but if you are in that group it'll cost you way more than making sure it's not an issue..
    I bought my 07 with 70,800 miles in May '16, put about 16k on it since, I've had tb/wp/cf changed, 6 tires, oil, and some sensor I can't remember the day I brought it back to get diagnostics. The only unexpected problem so far is a bolt falling off a control arm. So everything included maybe about 2.5k and I'm hoping no issues for a while, drives perfectly fine even the rare times I get on it
    Dec 05 2016
    miami FL
    why do you use 0W40? because of the cold weather?
    Coolant flange
    Part: $50
    Labor: $70
    Coil packs
    PCV Valve
    Part: $45
    Parts: $280
    Labor $400
    Parts: $380
    Labor: $400
    Fuel Filter
    Part: $40
    Installed myself
    Parts: $35
    Labor: $180
    $2,020
    Dec 05 2016
    miami FL
    OEM coils really cost $170? were they the red tops. i replaced mine but i dont remember it costing that much for a set of 4?
    Coolant flange
    Part: $50
    Labor: $70
    Coil packs
    PCV Valve
    Part: $45
    Parts: $280
    Labor $400
    Parts: $380
    Labor: $400
    Fuel Filter
    Part: $40
    Installed myself
    Parts: $35
    Labor: $180
    $2,020
    Dec 05 2016
    miami FL
    jack the car and then jack ur ...
    Dec 05 2016
    miami FL
    you and the damn chain tensioner! btw are the rings your talking about, what they hell are those?!?
    Dec 05 2016
    miami FL
    punched in the face!
    Dec 05 2016
    miami FL
    6 tires in 16k miles. wow you must love keeping the rubber companies in business!
    Quote Originally Posted by tloft4 View Post
    Veteran Member Three Rings StatusQuo's Avatar
    Jun 15 2016
    Northern California
    Quote Originally Posted by ahotboy15 View Post
    I've been doing some research and the Mobil 1 0W-40 seems to be one of the best, if not the best oil that is 502.00 spec per the 540ratblog.
    I use it in my car personally.
    Sent from my ONEPLUS A5000 using Audizine mobile app
    B7 Audi A4 Quattro - Built. Not Bought.
    Upgraded HPFP | RS4 Injectors | RS4 LPFP Controller | 175 Bar PRV | 50/50 E85 | Straightpipe Exhaust | Cold Air Intake | Big Turbo | Front Mount Intercooler | -- The Maestro Community Project --
    Nov 07 2015
    2004 Jeep Wrangler Rubicon, 94 Z28
    Pennsylvania
    Quote Originally Posted by StatusQuo View Post
    Blind squirrel found a nut! I have been using this oil since my first oil change, mostly because it was on sale and I decided to stick with the same oil since then
    2006 A4 6MT - JHM Stage 2 93 Oct flash | Cam Follower Conversion | JHM HFC | JHM Downpipe | B6 S4 Exhaust | JHM HPFP Internals | JHM Small Core FMIC | 034 RSB | Sway Bar Endlinks
    Jun 15 2016
    Northern California
    Quote Originally Posted by Rulty View Post
    Nice. Yeah you can grab the oil at Walmart for 27 bucks. Cheap and good stuff.
    I hate Walmart so I just get a price match at o'reilly's lol.
    For oil filters, believe it or not the Fram Ultra Synthetic is actually very good. I used it on my last oil change and was very impressed on the build quality of the filter. Did some research on it and the filter properties is around the top 1/3 of the oil filter lineup on the bobistheoilguy forums. The build quality is actually better then the Mann oil filters.
    Right now I'm using a NAPA gold filter which is a rebranded wix.
    Veteran Member Three Rings K1196A's Avatar
    Feb 16 2007
    B9 S4, 2018 Q5, 2012 Tacoma TRD Sport
    DOVER, PA
    I was just thinking the same thing... I did those all myself (with help from youtube and DIYs here) - glad I suffered through!
    Feb 15 2016
    Cambridge,Ontario
    just curios .. have you ever posted anything that actually helped anyone ???
    1976 Yamaha XS 360
    May 15 2016
    Lock Haven, PA
    Had a nail in one around 4k into it's life, changed both fronts
    Mar 12 2018
    Minnesota
    The audi dealership closest to me told me to only use 0w40
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    OEM parts FTW
    I do the same for all my cars. Spreadsheet/Excel file with auto-sum (-/+) for all works performed from and by. I also see that you're one of the old veterans here at Audizine based on your joined date, just a day before me!
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Apr 30 2017
    2006 A4 Avant with tune, 1976 Ford (Mercury) Capri II, 1990 Vw Vanagon & a 2007 Toyo Sequoia
    Amherst NH USA
    I'm terrified to have a spreadsheet telling me where all monies gone, especially if the wife gets to see it, lol
    Sent from my SM-N950U using Audizine mobile app
    Veteran Member Three Rings jhoward's Avatar
    Dec 13 2012
    central NY
    Quote Originally Posted by nij_tp View Post
    Yeah, I really don't want to know
    OP: if you get that V8, expect your costs to go WAY up. But they're fun as hell to drive and totally worth it. MT6 or bust
    Oct 08 2007
    Jersey City
    Quote Originally Posted by 80sGuy View Post
    one day before you..haha nice! AZ taught me sooo much about my B5 and B7! It's great to pass along knowledge that I have learned from here.
    hahaha I agree and too funny! I mainly use it to track miles between oil changes, filters, brakes etc. Just keep another spreadsheet with the 'fun' purchases and hide that from the wife!! lol
    Sean
    The New
    The Old
