Results 1 to 7 of 7
    Veteran Member Four Rings rhfosu's Avatar
    Jan 01 2015
    Alexandria, VA
    Cooling fan replacement DIY?
    My AC compressor took a shit bc my aux cooling fan took a shit and I didn't know it. I need to replace my fans. On my GTI, it was pretty straight forward...4 bolts and the fan assembly could be dropped from the bottom. For my b7 it looks like I need to put the car in service position, remove the core support, and loosen and/or remove the radiator. I looked for DIY and couldn't find one. Anyone have any advice, words of caution, etc.?
    "I don't understand Audi enthusiasts. They buy a car that looks like a bar of soap, then they spend money modifying it so it looks slightly less like a bar of soap."
    Jan 01 2015
    Alexandria, VA
    Bueller...Bueller...
    Senior Member Two Rings KMAzz's Avatar
    Jun 03 2010
    2010 Nissan GTR, 05 S4, 03 A4
    Bethlehem,PA
    put it in service lock and suspend with bungee cords so you can hang it off the snub. This will give you enough room to move all wiring and wiggle it out the top. Not too bad of a job. No need to pull rad
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Buy a whole new shroud with fans on rockauto. I paid $150
    Sent from my SM-G960U using Audizine mobile app
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Veteran Member Three Rings B7S3wannabi's Avatar
    Mar 27 2017
    2005 ZCP Competition M3, 2016 Audi S3, 2018 Tesla M3P, 2016 Ducati 959
    Loudoun County, VA
    Is it the fan or the controller? Did you put power directly to the motor?
    The fan module can be done without putting the car into the service position but not the fans.
    2006 Sline A4 Quattro 2.0T - K04R - Sold
    2016 SQ5 Black Optics - Mythos Black - Sold
    2005 BMW ZCP Supercharged M3 in Nardo Gray
    2016 Audi S3 Black Optics - White
    2018 Tesla Model 3 Performance - White
    2019 Ducati 959 - White
    Jan 01 2015
    Alexandria, VA
    Quote Originally Posted by B7S3wannabi View Post
    It's the 300mm fan, near as I can tell. I tested the resistance and it was high. When you turn the blades by hand, it makes a grinding noise as well. I'm assuming the module is ok. I bought the TYC assembly for $100 off of ebay. Looks like a lot of vendors stock that piece, including europaparts. I would replace the module to be safe while I had it apart, but it's pretty pricey.
    Mar 27 2017
    Loudoun County, VA
    Quote Originally Posted by rhfosu View Post
    TYC is solid for the price.
    Module cost does suck but definitely recommended. Much easier to replace while you have it all apart. Unless you can confirm it's good by commanding it with VagCom and using a test light.
