Results 1 to 14 of 14
    Active Member One Ring chrishero's Avatar
    Oct 14 2017
    Mulberrry, FL
    Unhappy Post Oil Change Transmission Errors Displayed - 2013 A6 Quattro 3.0
    Hey guys! I changed the oil on my 2013 A6 Quattro 3.0 PP last night.
    After starting the car back up, I started to get a 'no reverse gear - continue driving' error, shortly followed by a 'general transmission error, put car in park' message.
    Has anyone else encountered this? I have had zero issues with the car up to this point.
    Thanks for the help!
    Veteran Member Three Rings SlickMachine's Avatar
    Feb 21 2012
    2018 Ford Explorer Sport
    Aurora, CO
    Quote Originally Posted by chrishero View Post
    Need to scan it.... Do you have VAGCOM?
    Just curious: did you jack the car up, use ramps, or use an extractor to change oil?
    Sent from my SM-G950U using Audizine mobile app
    Senior Member Two Rings BrianVan's Avatar
    Apr 03 2015
    Naperville, IL
    Oil change meaning the engine oil, or Transmission "oil"? If you changed your engine oil, that has nothing to do with the transmission and is purely coincidental. Unless you knocked some connector loose under the car or engine bay. But that's highly unlikely and hard to do on accident changing the engine oil.
    If you did a transmission drain or dropped the pan and changed the filter, (highly involved procedure), you may not have filled enough trans fulid back, didn't run the gears properly, a number of other drain and replace steps for tranny fluid change.
    Cycle thru the MMI and check settings for engine oil level and see if you have dynamic settings, change those back and forth and see if it comes out of its funk.
    If not, its a trip to the dealership or call around an euro Indy or transmission shop and see if they work on Audi 8 speeds.
    Oct 14 2017
    Mulberrry, FL
    Right on, my brother is going to let me borrow his VCDS.
    I used ramps.
    Oct 14 2017
    Mulberrry, FL
    Thanks Brian, it was engine oil. MMI was showing full oil this morning when I checked.
    Oct 14 2017
    Mulberrry, FL
    Exclamation dumb dumb dumb
    I'm an idiot, bonehead mistake. It was a total hindsight is 20/20 and all the clues started lining up. I drained tranny fluid and added oil.
    I haven't run it much at all, only enough to run the VCDS on it. Got three main errors:
    12481 - Transmission Friction Element / Clutch B
    P2701 00 [096] - Apply Time Implausible
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 89666 km
    Date: 2018.04.02
    Time: 21:50:56
    Unlearning counter according OBD: 40
    Voltage terminal 30: 13.862 V
    Engine speed: 1223 /min
    Transmission input speed: 1112.00 /min
    Transmission output speed: 448.00 /min
    Transmission fluid temperature: 67 ∞C
    Driving position: d
    M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
    M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
    M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
    Current N215 Pressure control valve 1: 50.0 mA
    Current N218 pressure reg.valve 4: 850.0 mA
    Current N216 pressure reg.valve 2: 850.0 mA
    Current N233 pressure reg.valve 5: 850.0 mA
    Current N217 pressure reg.valve 3: 50.0 mA
    Engine torque: 21 Nm
    Current N443 pressure reg.valve 7 main pressure: 850.0 mA
    M015_Time Normal Mode: 395 s
    M019_Time Since Reset: 7650 ms
    M014_Time Since Shift: 2550 ms
    12521 - Shift Monitoring
    P0780 00 [096] - Shift Error
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 89666 km
    Date: 2018.04.02
    Time: 21:51:00
    Voltage terminal 30: 13.900 V
    Engine speed: 1400 /min
    Transmission input speed: 1263.00 /min
    Transmission output speed: 431.00 /min
    Driving position: d
    Current N216 pressure reg.valve 2: 50.0 mA
    Current N217 pressure reg.valve 3: 850.0 mA
    Engine torque: 54 Nm
    Current N443 pressure reg.valve 7 main pressure: 728.7 mA
    M015_Time Normal Mode: 398 s
    M014_Time Since Shift: 5970 ms
    22083 - Reverse Gear
    P0736 00 [032] - Incorrect Ratio
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 89666 km
    Date: 2018.04.02
    Time: 21:44:03
    Voltage terminal 30: 12.947 V
    Engine speed: 722 /min
    Transmission input speed: 479.00 /min
    Transmission output speed: 21.00 /min
    Transmission fluid temperature: 61 ∞C
    Driving position: R
    Current N215 Pressure control valve 1: 850.0 mA
    Current N233 pressure reg.valve 5: 50.0 mA
    Engine torque: 41 Nm
    M015_Time Normal Mode: 35 s
    M014_Time Since Shift: 7650 ms
    Trying to get it towed either to the local Audi dealer here in Lakeland or to a euro shop in Brandon today.
    Thanks for the suggestions and replies, gents.
    -Chris
    Jun 26 2012
    Rockford, il
    WoW. Poor Audi. Reminds me of this story https://jalopnik.com/lazy-idiots-at-...pan-1748394648
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    Oh boy. An expensive lesson to be learned. I suggest purchasing and using this next time.
    Trans fluid is around $30/qt, you’ll need about 4 qts, and then whatever oil is, hour or two of labor, you'll probably be out the door for $350-400.
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Oct 14 2017
    Mulberrry, FL
    Quote Originally Posted by GilliamOS View Post
    Thanks Gilliam. I'll definitely be picking up a pump for next time. Lesson learned! D'oh!
    May 26 2015
    Mormon Country
    It's the Audi recommended way to change the oil and more refined way at that. It's been years since I crawled under one of my cars to change the oil.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Jun 26 2012
    Rockford, il
    On the S cars the filter is on the bottom so you have to crawl under anyways plus you can inspect your car underneath.
    May 26 2015
    Mormon Country
    Quote Originally Posted by Fociracr View Post
    Oh that's no fun. I've been spoiled as mine have always been top-side access.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Senior Member Two Rings 13_C7_SC's Avatar
    May 01 2016
    2011 Range Rover Sport
    Glenside, PA
    Ouch!!!
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    Expensive lesson
    19 years and 320,000 miles behind the wheel of an Audi
    2022 A6 55 3.0 Prestige with Luxury Package and Black Optic Sport Package (all options). Daytona Gray Pearl Effect. Sarder Brown Interior. (July 2022 - presesent)
    RIP Audis
    2015 A6 TDI Prestige All Options except B&O - (August 2014 - July 2022) (146,179 miles)
    2005 A6 4.2 Prestige All Options - (February 2005 - August 2014) (141,179 miles)
