Originally Posted by
brad65ford
LOL I get that, the Eventuri intake is one bad ass looking intake for sure no one can disagree with that so for looks its a win win for performance, though it may not do any more for flow then say adding a k&n filter but then again its goes in line with someone adding rims (does nothing for performance but looks killer) so I get it. Its just sad when these companys create these super kick ass looking systems, state if flows more then stock but didn't address the main restriction is what I was reflecting on. Now if Eventuri did what SRM has done to the other side of the intake by the turbos then hell yeah, right on no qualms.
Results i've seen are only from Big Tubro RS6 or RS7 I think in Canada or overseas its mostly shops Sean has work with and using his Big Turbo kit (his main business). Sean can share this, believe there is someone else doing some back to back 1/4 mile runs between the stock and the SRM intake so more will pop up. Most data a side from not my own rs7 (since I haven't dyno'd or dragy'd yet) have all datalogged 2 psi increase which just these intake pipes. I forget the exact suggested hp increase suggested on a stock or tuned rs7 (this is where there is grey areas) its something like 20-40hp increase. Again Sean can be more specific. In short you will see more and more people that care about every last bit of hp running SRM pipes period, no other way to state it.
There you go again...lol.
Beauty is in the eye of the beholder...we just disagree on what a work of art they are. That’s all good though, I do admire your enthusiasm.
Just so I have this straight, Sean says that bolting these intake tubes on an RS7 (let’s say Stage2) have created a 2 psi increase?
I don’t understand how that would happen. Wouldn’t the ecu lower the duty cycle for the wastegate and maintain the psi it was tuned for? I’m admittedly new to Audi but that’s usually how modern cars respond.
Edit. There are a lot of us here who are chasing improved performance and that unites us. I don’t expect an answer to the above question as the 2 psi increase is hearsay at this point in time, so it wouldn’t matter. I only offer my opinion to encourage people to, “think before you drink”.
Take care and hope you have a good weekend.
Sent from my iPhone using
Audizine
