Results 1 to 17 of 17
Thread: Starting
    Apr 01 2018
    boulder
    Starting
    Hey new to Audi where should i start on my 03 A6 2.7t
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    ummm . . . with what exactly?
    that's a vague nondescript statement
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    May 20 2010
    Quote Originally Posted by CBAudiA6 View Post
    Did a double-check to make sure it didn't say "allroad". Breathed a sigh of relief.
    Honestly, make sure the car is right mechanically and electrically, as well as tires, brakes, and suspension before you think about doing anything. If it is, then it depends on your tastes. Stage 1 is a good, low budget upgrade, as are sway bars, and upgrade the brakes.
    Apr 01 2018
    boulder
    Yeah i had it checked out by an Audi tech and he said it’s all good but one of the turbos has oil slowly leaking into it
    Veteran Member Four Rings cu52's Avatar
    Dec 11 2008
    Denver Metro
    How many miles? Any maintenance history? If not start with all the maintenance to make sure it is current!
    13 Tundra SUPERCHARGED
    01 B5 S4 Avant, C5 RS6, 18 SQ5
    Gone:
    03 RS6, 01 605 Tial Avant, 00 S4, 01 S4 Avant, 01 Imola, 00 Hibiscus, 04 4.2L Allroad 6 speed swap, 03 allroad, 04 Audi Allroad 6MT 2.7T ST3!, 04 Allroad TIP, 02 Allroad MT6 2.7, 08 Toyota Sequoia, 04 Audi S4 MT6, 01 S4 Casablanca White 6MT , 04 VW GTI 5MT, 03 A4 Avant 3.0 6MT, 09 Tundra CM, 11 Tacoma DC, 02 A4 Avant 3.0 Tip, 01.5 S4 Avant tip GIAC stage 3-, 00 S4 6mt
    Apr 01 2018
    boulder
    Quote Originally Posted by cu52 View Post
    95k previous owner took very good care of it
    Active Member Two Rings Reece_'s Avatar
    Nov 01 2017
    Battle Creek/MI/United States
    95k? Hmmmm get ready to dump money into turbos!
    Veteran Member Four Rings m_haiser's Avatar
    Apr 24 2011
    2012 A6 Prestige, 1998 Jeep Cherokee XJ
    Central Willamette Valley
    Quote Originally Posted by Reece_ View Post
    really? I'm at 213k miles on original turbos.
    Feb 21 2016
    2002 A6 2.7t manual swap
    Colorado
    I'm at 170k on original turbo's. But even if they do go out, good K03's are plentiful and cheap.
    As far as general maintenance items to look for - ICM's, PCV & pancake valves, O2 sensors, EGT modules, timing belt, water pump/t-stat, all braided vacuum lines, torque converter if it's an auto otherwise the clutch and 1-2 shift collar if it's a manual.
    Nov 01 2017
    Quote Originally Posted by m_haiser View Post
    No way!!!!! 213k??? That’s awesome. I made it about 134k(ish)
    Apr 24 2011
    yeah just bought it a couple months ago and had a stack of maintenance receipts. pretty well taken care of actually. I do get a bit of smoke on hard acceleration but I haven't dug into pcv system or intercoolers (since they fill with oil) to see if one of those is the cause.
    Apr 29 2009
    Quadzilla
    Longmont, CO
    95k? Hmmmm get ready to dump money into turbos!Audizine
    nope . . . 236k here, when one uses the correct oil and lets it rest 30-60 sec after honking on it, they will last
    Rockin' the Rockies
    Jul 25 2016
    1995 Land Rover Discovery
    Missouri
    Nice! Can't believe somebody has me beat, I think my first C5 is at about 230k on the originals. Just gave it to my brother when I got my 6 speed car, we're both curious to see how long they're going to make it.
    Apr 01 2018
    boulder
    I have faith now!!
    Aug 27 2017
    Pa
    Start here:
    Put the car on jack stands. Rip out the entire front suspension and replace it. Check the subframe and timesert it if it's stripped. New rotors and caliper rebuild, powder coat the calipers. take the engine/trans out and replace the torque converter, transmission filter and gasket. Fully rebuild the engine (bearings, studs, gaskets) inspect the turbos, test waste gate actuators and replace if necessary, inspect the heads and replace components as necessary. Convert to all silicone boost and vacuum hoses, test and replace check valves and solenoids. Replace the spider hose/PCV valve. Inspect all harnesses for damage, replace as necessary. Replace alternator and starter motor. Inspect and replace leaky power steering pump, hoses and rack. Inspect and replace half shafts and drive axle. DON'T FORGET TO BUY ALL NEW HARDWARE because you can't re-use 99% of the stuff once you remove it! Replace air/ cabin air and oil filter. Clean intercoolers and radiator and inspect cooling hoses and reservoir and replace as needed. Buy new injectors and spark plugs (check the gap). Replenish all fluids. Then move to the back and replace the entire suspension and brakes. Inspect the exhaust. Then wrap all 4 wheels in new rubber. Move to interior and replace broken visor clips, peeling headlight switch, mirror switch and get sticker replacements for the peeling HVAC controls. New armrest. Move to exterior and do a 3 stage paint restoration and de-fog lights.
    Now you'll have a complete service record and won't have to worry about anything for 10 more years. All of these things are where you could start.
    Senior Member Two Rings Alex JB's Avatar
    May 08 2014
    Leicestershire, UK
    I had a spare 1/2 hour tonight after dinner so got most of that list done
    Veteran Member Four Rings hoganalley's Avatar
    Feb 23 2007
    Burlington
    Quote Originally Posted by Alex JB View Post
    Lol ^
    Sent from my ONE A2005 using Audizine mobile app
    14 A4 allroad - stock
    05 allroad 2.7T Stock
