I initially had a fuel pump cutout switch installed so I could crank the engine with no fuel pressure to build up oil pressure. This worked OK, but if there was some residual fuel pressure then the engine might fire.
I then installed an Accusump, which worked fine, but was some expense and effort to install.
Link:
https://www.audizine.com/forum/showt...st-impressions
About a year and a half ago I did the chain service. All went fine, but I always wanted to stop a repeat of the problem, so I re-installed the Accusump.
Over the last couple of months I started looking through the wiring diagrams to see if there was a solution that worked better and was easier to do. I wanted to find a way of cranking the engine and have it not fire by isolation of either the ignition coils or the fuel injectors.
As it turned out, there is a very easy way of isolating the ignition circuit. If a switch is put across this circuit, you can crank the engine for a few seconds until you think you have built up oil pressure, then close the switch, and the engine will fire immediately. This builds up the pressure in the oil gallery to stop the rattle, but also pre-oils the engine while it’s turning. To me the perfect solution.
Take a look at the applicable portion of the wiring diagram below. Note, this is for a C5 Allroad. The engine in the S4 is identical except for the camshaft and the DME tune. I’m not sure if the wiring is identical. Someone with access to these diagrams might be able to confirm this. Pulling different fuses and turning ignition to position 2 and see what codes appear might also be a way of confirming this.
The green arrows show the direction of current flow. It starts at the top at position 80. This from memory comes from the main DME relay and then travels down to Fuse 229 (fuse 29 on the cabin fuse panel). This then flows on to be the power supply for the ignition coils. D23 is the main supply wire for the ignition coils. N291, N292 are two of the eight ignition coils. All the others are attached to this as well (not shown in my screen shot). For interest, J220 is the DME.
The great thing is that the only thing connected to fuse 29 is the ignition coil circuit. There are 4 different fuses in the cabin panel that are for engine management. The problem is that all the others are for multiple systems. If you isolate the other circuits you can get a similar result as what I’ve achieved, but you will get multiple engine codes and possibly other unwanted results. By isolating the ignition coil circuit you don’t get any engine codes, and it starts perfectly.
If you look at the accusump thread (link above), there are a few pictures showing the fuse panel opened up. It’s easy to also unbolt the relay panel that you can see in the photos, as well as disconnect the plastic wiring guard that is behind the fuse panel which holds all the wires going to the fuse panel. Then you can have easy access to the whole wiring loom.
Make sure you cut into the correct wire. One side of fuse 29 has two wires attached (see wiring diagram above). The other side of the fuse has only a single wire. This is the one you want to cut into. Also, you can see the gauge of the wire is 2.5mm. You need to use a wire to the switch that is similar, and can handle current in excess of the 30A fuse. The switch is mounted to the left of the steering wheel so I can turn the key with my right hand and switch the ignition on with my left. If you are worried about accidentally knocking the switch off while driving (the engine will stop immediately), you may want to use a guarded switch.
If you look at the accusump thread, you will see the wire and switch I used for the fuel pump. I used the same wire and switch, but it now can open the ignition circuit rather than the fuel pump circuit. It's position is such that I would never accidentally turn it off so I haven't bothered with a guarded switch.
So the end result is this.
Accusump removed. Switch installed for the ignition. I simply crank the engine for an appropriate amount of time to build oil pressure (with the switch in the off position), and then turn on the ignition circuit switch while I’m cranking. The engine fires immediately. No fault codes or anything to say it’s been anything but a normal start.
Depending on how long the car has been sitting will determine how long I crank for. The car is a spare that might only be started once a month. If this is the case, I might crank for about 5 secs prior to turning the ignition on. If it has been recently running, I might give it two seconds. Experience will tell you what your engine needs.
Regardless, the engine starts perfectly, like it was running only moments before. You realise why many racing engines are started in this way (crank for oil pressure prior to firing). You only have to listen to the engine to realise it likes it.
Total cost: Less than $10 and about two hours.
