Results 1 to 10 of 10
    Veteran Member Four Rings audibmi's Avatar
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    Front and rear dash camera installation DIY
    This is my version of a front and rear dash cam install. I opted for two separate 1 channel dash cams instead of a typical 2-channel system because:
    1. I wanted to avoid running wires front to rear for ease of installation
    2. Separate cameras have better resolution compared to 2-channel systems which sacrifice rear cam quality
    3. SD cards don't have to be large capacity since storage is split over two cards. Also less rewriting cycles prolong the SD card
    4. I wanted to run only one camera in parking mode to extend the run time with an external battery
    I went with the Blackvue DR750S-1CH due to the small form factor, allows viewing footage wirelessly while recording, ability to download files to my iPhone, and most importantly, the ability to switch to parking mode automatically. Blackvue is also not as finicky with 3rd party SD cards (like Thinkware).
    Parts List:
    2 Blackvue DR750s-1CH cameras
    1 Cellink Neo external battery (for rear cam parking mode). You can check remaining battery levels using a bluetooth app.
    2 Sandisk Endurance 64GB micro SD cards.
    *Caution* use SD cards specifically designed for repeated read write cycles only or risk premature failure. If you have a lot of time, here is a good explanation: https://www.rdforum.org/index.php?threads/57805/
    1 Mirror tap for front camera. I chose the RadarMount version as it was cheaper and the barrel is a perfect fit for Blackvue.
    1 Blank aluminum business card for mounting rear camera. Any rigid plastic credit card size card will also do the trick too, but won't look as nice.
    Step 1:
    Pry top piece of mirror cover to expose wiring harness.
    Step 2:
    Plug in mirror tap wires. Blue/red wire is switched 12V and Brown wire is ground. Your mirror may differ so have a voltmeter on hand to test. I chose the mirror tap option to avoid the hassle of running wires to the fuse panel.
    Step 3:
    Mount camera lens directly in front of and as close to the bottom of the rear view mirror so it's centered. I found this position gives the camera full unobstructed view with minimal glare from the dash. With the mirror tap, no wires are visible from the outside for a clean look.
    Step 4:
    Power cable can exit through small opening without need to drill hole in the cover. From the inside, the camera is almost fully hidden from driver view as it sits behind the rear view mirror.
    Step 5:
    Mount rear camera underneath the headliner. Using a bent blank aluminum card to stick the camera mount on. Tuck wire under weather stripping.
    I avoided mounting on the rear glass because I didn't want to risk damaging the camera every time I slammed the hatch shut. Also, slack is required in the power cable to allow opening/closing of the hatch. If you have tint on the rear glass, removing the camera mount may cause damage as well.
    Step 6:
    To power the rear cam, simply plug in the 12V socket. In my case, I have a separate external battery to run the rear camera 24/7 to avoid draining the car battery. Since the TTRS doesn't have a spare tire, there is lots of space underneath to hide the battery, but I've left it exposed in the photo so you can see how it's wired.
    The Cellink Neo provides over 30+ hours for my rear camera. After leaving my car parked overnight, it only takes ~15-20 minutes to top up to full charge. The Neo has an option to charge faster if you wire directly to the fuse panel with higher current, but the 12V socket is fast enough for my needs.
    For those that may only need parking mode occasionally (i.e. parking in a sketchy area), a cheaper option is to get a readily available 5V power bank and a 5V to 12V convertor cable. Also useful for powering camera when removed from the car.
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    Cellink Neo dashcam battery relocated underneath the trunk. Since the TT RS does not come with a space saver spare, there is quite a bit of storage space in the foam compartments. Perfect place to store your owners manual, etc.
    The same pins from the rear view mirror harness used to power the front dash cam can also power a Uniden R3 at the same time.
    Established Member Two Rings Fifco's Avatar
    May 27 2017
    Oak, CA
    Great work, thanks for sharing!
    2017 TTS #VegasYellow (034 Rear sway bar, X34 Intake & Subframe mods, Milltek CatBack, StopTech ST-60)
    2015 Golf GTi Autobahn (Sold/Lease Ended)
    Senior Member Two Rings shifu22's Avatar
    Aug 28 2016
    B8-S4, MK3-TTRS
    Coquitlam
    Looks like my setup! I used the Thinkware front and rear dash cams though. And a K40 radar. Otherwise. Same idea. I just avoided the extra battery setup in the rear! IMG_0025.JPGIMG_0024.JPGIMG_0026.JPG
    B8-S4
    MK3-TTRS
    Junior Member One Ring StraySheep's Avatar
    Sep 25 2010
    Toronto, Canada
    Nice install. Is the front cam on 24/7 or shuts off when car is off since it's getting power from the rear view mirror.
    2018 Audi TTRS | Nardo Grey | Nappa Leather Red Stitching | brembo Bang & Olufsen MICHELIN
    2022 Lexus NX 350h Luxury | Cloudburst Grey | Nuluxe Rioja Red | THULE
    2006 Nissan 350Z M6 Grand Touring | Glacier Pearl (White) | Charcoal Leather | nismo brembo RAYS JDM Nissan MOTUL BOSE MICHELIN
    Veteran Member Four Rings nefkntym's Avatar
    Jan 30 2007
    a bunch of tools
    Monument, CO
    Awesome, subbed for more info.
    2023 Q7 - Ibis White
    2024 SQ8 - Chili Red
    So many have come and gone…
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    Quote Originally Posted by StraySheep View Post
    if a mirror tap is used, camera will turn on/off with ignition. constant power 24/7 can only be provided if wired to an unswitched fuse tap or external battery.
    Aug 28 2016
    B8-S4, MK3-TTRS
    Coquitlam
    I have mine wired direct to the battery. It was kind of a pain but that way I have 24/7 motion and park protection on.
    B8-S4
    MK3-TTRS
    Sep 21 2017
    2018-TTS
    Philadelphia Suburban
    Audibmi,
    Nice install. Can you provide more detail on rear camera install? How did you hook on to the edge of the headliner? I don't see much room there when I tried.
    Thanks
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    Quote Originally Posted by jeteye View Post
    udibmi,
    Thanks
    you only need to fold the top edge of the card a little over 1/2" to form the hook. as long as your card is clipped on the edge, the trick is to wedge the camera barrel tight up against the bottom edge of the headliner. this creates downward tension on the "hook" of the card to hold the camera snug.
