Results 1 to 13 of 13
    Mar 26 2018
    97 wrangler, 14 silverado, 00 silverado, 99 prelude type sh
    salt rock, wv
    harsh vibration randomly under braking and at highway speeds HELP!
    replaced axles, front rotors and pads, new tires and wheels and had alignment shop check bushings all were in good shape. its mostly coming from the front right it feels like the whole wheel is going to tuck under the car and fall off need suggestions its driving me crazy!
    Veteran Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    So the vibration is happening during braking.
    But then you also say at highway speed... like when your braking or just driving along?
    If it’s under braking i would consider its the Rotor particularly on the right side as you mentioned.
    New doesn’t always mean it’s not broken.
    Just some thoughts.
    Veteran Member Four Rings VR6Bomber's Avatar
    May 13 2009
    XXXX
    As said, sounds like a warped rotor.
    Mar 26 2018
    salt rock, wv
    Quote Originally Posted by JustManson View Post
    Just some thoughts.
    Just driving along at 70ish it vibrates enough to see the passenger seat visibly shake and it felt like it was coming from the right side before and after new rotors
    Sent from my SM-G892A using Tapatalk
    Veteran Member Three Rings cinimod25461's Avatar
    Dec 04 2013
    CA
    Could be warped rotor. Make sure your wheels aren't bent/damaged.
    Maybe get your wheels balanced and make sure your lug bolts are all tight.
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    "harsh vibration randomly under braking......"
    Not to sound like a smart-ass----Did you bed those new pads to those new rotors.......
    Mar 26 2018
    salt rock, wv
    Quote Originally Posted by LJS View Post
    To be honest I dont know what that means
    Apr 08 2013
    Connecticut
    Take some time and do a bit of reading-----
    [IMG][/IMG]
    Feb 27 2011
    Winnipeg
    check the hub face under the rotor to make sure there's no rust build up, that will give the feeling of a warped rotor, I'd double check all your ball joints, I had a loose upper control arm and tie rod give me some vibrations under braking before.
    Oct 11 2016
    Connecticut
    at 70mph and your vibrating more than likely a bent wheel, or wheel out of balance.
    When braking the vibration could be the bent or out of balance wheel and also if you didn’t do a proper brake “bedding” or brake-In of the new rotor and brake pads.
    Taken from the net.
    When braking the vibration more than likely is a bad rotor could be from not “bedding” the pad to the Find an open stretch of road that will allow you to safely stop your vehicle multiple timesAccelerate to 35 mph and apply moderate brake pressure to reduce your speed to 5-10 MPHRepeat this process 3-4 times, the goal is to warm up your brake padsNow turn up the heat even more by increasing your speed to 45 mph and braking down to 10 mphRepeat this process 3-4 times Pro Tip: It’s important to avoid coming to a complete stop during this stage as it’s possible to melt brake pads against hot rotors. Of course, should a deer, pedestrian or Sasquatch run onto the road, feel free to mash the brake pedal. Safety first!Your stop-and-go session is now complete. Park the car and allow the brakes to fully cool for an hour. For best results, avoid pressing down on the brake pedal when parked
    Mar 26 2018
    salt rock, wv
    Thanks for all the help guys! I need to check a bunch of stuff i guess
    Jul 25 2014
    MI
    I once had an issue with my ABS ring on one of the axles. Might try looking into that also.
    Mar 26 2018
    salt rock, wv
    Quote Originally Posted by s9chelil View Post
    Did that cause vibration? Because i have an abs light on also
