Just replaced my turbo, TIP, a couple vac hoses that looked bad, and put a new battery in. Once I got my car all buttoned up it misfires pretty bad at about 800 rpm and it is just as bad if you give it any gas. I then got new plugs and coil packs, as mine did not look very good. still misfires. Found sjp and a prv valve that were bad, going to replace those and hope it'll run. Also have a crack in the hard plastic inlet hose from the airbox to the sai pump, would that affect how my car ran? I have a check engine light but don’t have a computer I can run vagcom on. I was hoping someone would be willing to pull some codes for me. I live in Leadville but I would be willing to work something out to make it worth your while. Really hurting here need to get my car running!
