Results 1 to 3 of 3
    Veteran Member Three Rings charlatan's Avatar
    Apr 13 2007
    MOLINE, IL
    Car horn won't stop after new steering wheel install
    It was pretty straightforward...I don't understand why it's happening. Any ideas? It's only when the car is switched on. It is awful. Never dealt with this before, but a little research indicates that it is probably the clock spring...it did come uncoiled a bit and i coiled it back up when i put it back together...anything i should know to fix it?
    theROGUEdesigner
    Jul 26 2017
    Dunedin/FL
    Bose Noise Cancellation Headphones? Unplug the fuse for the horn.
    Sep 16 2010
    Central Wash
    The metal 'ring' type thing just under the airbag is bent a little, the contacts are touching and honking the horn. Pull the airbag off and fiddle with that, creat a little gap between the contacts by slightly bending it and you'll be fixed.
    It's not the clockspring.
