Results 1 to 35 of 35
Thread: Tuning Question
    Mar 25 2018
    Tuning Question
    I want to know the community's opinion on eurodyne tuning. They are a company out of Ottawa, ON; see http://www.eurodyne.ca.
    I am looking into tuning my A4 but cannot decide between APR, Eunitronic or Eurodyne. Eurodyne appears to offer the most increase in power, 267/330 respectively.
    Has anyone purchased this tune? Is it good. What else would you reccomend in this price range, $500-600?
    Active Member Four Rings Nano909's Avatar
    Jul 25 2016
    California
    I went with APR because their tunes are known to be conservative for longevity and reliability, also for their huge increase of power. I daily this car so that was a huge factor.
    Mar 25 2018
    Do you find that it gets rid of the turbo lag? As well, how much torque and horsepower did you gain from the tune?
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Quote Originally Posted by adamleaf8601 View Post
    Almost all of the stage 1 tunes are comparable, roughly +60 hp +60 torque. APR's claims are actually slightly higher (284/338 crank on 93 octane) than the Eurodyne numbers you posted. And yes the boost kicks in much earlier, near 2,000 RPM. I also went with APR due to their large install base and the correlated reliability, as well as the easy access to authorized tuners.
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Mar 25 2018
    Quote Originally Posted by Project Quattro View Post
    Does APR void your factory warranty? Is there any way to temporarily take off (and not leave a trace) the tune when bringing your car to Audi for warranty related work and diagnosis? My worry is if I get the tune and then the injectors fail, for example, then I wouldn't be covered because they detect the tune.
    Mar 24 2014
    Yes.
    No.
    Valid and likely. But worth it.
    Active Member Two Rings 05s-4Cab's Avatar
    Mar 19 2015
    09 A4 Avant Prestige, 05 S-4 cab
    Wrightsville, PA
    I just got the APR tune stage1 for my 09 avant and yes it has great take off but I have an issue. It was great but first gear over 4k it would hesitate hard and then take off again hard till shift to next gear then no issues after that through the next gears. So I called APtuning, where I got the tune and they thought it to be the diverter. So I got one. Put on and seemed to fix it but started to idle rough. Have four faults... I had the two actuators before when I changed out the coil packs had to replace those two connectors and had those two come up till I was able to get a good connection. Drove fine for several months till tune. I tried fiddling with them but they keep coming back and the other two have not. I had some misfire on those two cylinders one time as well. I tried to get these to go away a few times and now car will not start at all just turns over. I have not had any issues with car before the tune. Any ideas. Called the place as well they are not sure why thinking it is a coincidence. ??
    4 Faults Found:
    7207 - Cam Adjustment Actuator A; Cylinder 1
    P11A1 00 [109] - Elec. Malf. or Open Circuit
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 229341 km
    Date: 2008.03.12
    Time: 03:21:06
    Engine speed: 1083.50 /min
    Normed load value: 8.6 %
    Vehicle speed: 0 km/h
    Coolant temperature: 89 °C
    Intake air temperature: 63 °C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 11.709 V
    Unlearning counter according OBD: 40
    7225 - Cam Adjustment Actuator A; Cylinder 4
    P11AD 00 [109] - Elec. Malf. or Open Circuit
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 229341 km
    Date: 2008.03.12
    Time: 03:21:06
    10540 - Camshaft Adj. Bank 1 Intake
    P052A 00 [101] - Cold-Start Timing not Reached
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 229446 km
    Date: 2008.03.12
    Time: 10:12:20
    Engine speed: 1120.00 /min
    Normed load value: 26.7 %
    Vehicle speed: 2 km/h
    Coolant temperature: 33 °C
    Intake air temperature: 20 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 12.863 V
    4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
    P0016 00 [101] - Incorrect Correlation
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 229448 km
    Date: 2008.03.12
    Time: 10:16:58
    Engine speed: 792.00 /min
    Normed load value: 9.0 %
    Vehicle speed: 11 km/h
    Coolant temperature: 77 °C
    Intake air temperature: 18 °C
    Voltage terminal 30: 13.994 V
    Mar 25 2018
    Quote Originally Posted by 05s-4Cab View Post
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 229341 km
    Date: 2008.03.12
    Time: 03:21:06
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 229341 km
    Date: 2008.03.12
    Time: 03:21:06
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 229446 km
    Date: 2008.03.12
    Time: 10:12:20
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 229448 km
    Date: 2008.03.12
    Time: 10:16:58
    If the car won't start i'd first look at ignition related items. Check your spark plugs. Do a load test on the battery. Perhaps your starter needs to be replaced. There also seems to be some timing related faults, that could mean that the chain has skipped a few teeth or something related to the tensioner breaking (common on B8s).
    Mar 19 2015
    Wrightsville, PA
    Ok I was afraid of the timing chain issue but I have new coil packs and plugs since November. I just know that the actuators were an issue when I did that work because they were broke and had to replace them. That was not easy to get resolved a lot of playing around to get good connection. I did not want to tear the front end apart though(((
    Senior Member Three Rings DetRebel's Avatar
    Mar 20 2017
    Chevy Trailblazer (the real daily driver); previous car: '11 Brilliant Black B8 A4
    Detroit
    Look at the integrated engineering tune.
    You can add their tune yourself, idk if anyone’s checked to see if their undetected by the dealership when re-flashed to stock.
    Oct 20 2015
    Southern%20Hemisphere
    I second IE tune's - have gone stage 2 from stock, and it is excellent
    Veteran Member Four Rings Perry01's Avatar
    Jan 22 2016
    Touareg V8 FSI 8V A3 - B8.5 Q5 - MKVI GTI
    Hawaii and Utah
    +3. /\
    CPMA / CTS K04-0064 / IE custom tune / Wagner FMIC / Custom ZF8 TCU tune
    Dec 03 2016
    nowhere
    Quote Originally Posted by Nano909 View Post
    I don't know how APR or any tuning company can market themselves this way. From experience in the B7 forums where a good number have apr's software on their ECUs, they're no more or less problematic than any other.
    HEAR
    APR stage 2
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    Quote Originally Posted by DetRebel View Post
    I just checked out the IE website and the power gains are confusing. They claim 68bhp gain but the chart right above that shows gains of 45bhp.
    2011 A4 Avant Prestige S-Line
    Jul 02 2017
    Knoxville TN
    Mar 24 2014
    The ECU has a flash counter. Feel free to try it, but 99.99% chance it will be detectable. Best to go into any tune with the expectation that it'll void your warranty.
    Mar 20 2017
    Detroit
    Thanks for clearing that up. I’m in the high mileage club so that’s not an issue for me.
    I’m approaching 115k in with in a month or so. I have to do all the major maintenance repairs before I start looking at tunes.
    Mar 24 2014
    Definitely a good plan. Tune won't directly break anything, probably, but it's an added strain that I wouldn't recommend doing before the catch-up work is done. Get on that timing tensioner ASAP; I know of a few that have failed right around your mileage.
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    eurodyne has pretty much all but abandoned this market, and their tunes suck as does their software on this platform. APR is better by a long shot, and there are alot more up and coming brands like IE that are offering much better support.
    Jul 21 2004
    South Florida
    If youre in canada you may want to hit uo Unitronic for their local presence and flash at home capability.
    Mike
    2018 Audi S5
    Gone-
    Mar 15 2017
    California
    I had an apr stage 1 b8 a4 that had a catastrophic piston ring failure while the car was still under warranty, I got the car flashed back to stock and took it into the dealership and they didn't detect that the tune had been there and got it repaired under warranty. They also had a rep from Audi corporate come to inspect the car, so I would assume if it didn't get caught under those circumstances you could get away with it in any other situation. The shop that flashed it said they hadn't ever had a warranty voided because of it, only when people go into the dealership with the software on the car at the moment.
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    I contacted IE and they said their tune does NOT deactivate the flash counter so it will be detectable from the dealer and you will get TD1 flagged..
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Jul 21 2004
    South Florida
    Quote Originally Posted by PreciseD View Post
    The Flash counter is not involved in the auto scan that triggers TD1.
    Mike
    2018 Audi S5
    Gone-
    Feb 05 2014
    Quote Originally Posted by bhvrdr View Post
    Mike
    Not what I have heard or even been told by tuners... EPL to name one who resets the flash counter... And IE who said that even if you flash back to stock it can still be seen in a scan...
    Would you care to elaborate since you seem to know so much about it from all your posts on the subject?
    Jul 21 2004
    South Florida
    epl doesnt reset the flash counter and have written multiple times its not involved in a spec/actual.
    Sent from my SM-G935V using Tapatalk
    2018 Audi S5
    Gone-
    Feb 05 2014
    That is what I was told by Chris and what is said in the Q5 section... I guess we all misunderstood that or he was talking about something else...
    Thanks
    Deactivated Four Rings
    Jun 23 2011
    We have said many times that we do not touch the flash counter and with the Simos 8.4/8.5/16 ECU the flash counter is not part of Audi's testing protocol. No idea with the A4s and they have a totally different ECU.
    Jul 21 2004
    South Florida
    Thanks
    Quote Originally Posted by Tony@EPL View Post
    TD1 is not tied to flash counter. Audi did change their TD1 system.... its VERY easy to un-TD1 a car now a days, far easier then before and has ZERO to do with the flash counter.
    I will not post about this anymore publicly, but if any EPL customer inadvertently get TD1'ed (forgot to flash to stock or maybe needed an emergency tow in) - email us privately.
    This is not correct. Currently flash counter is not tied to TD1.... this has been well proven at this point by our customer base.
    So does your "stock" flash reset flash counter and checksum? Is it detectable at the dealer like the APR one is (even though they said it wasn't)?
    Currently the flash counter is NOT tied to TD1 and yes the checksum will match.... its an actual OEM file.
    Mike
    2018 Audi S5
    Gone-
    Senior Member Two Rings acidvoodoo's Avatar
    Mar 11 2016
    Providence
    Heres a noob question for you guys: Could you keep your original stock ECU, purchase another ECU have it tuned and swap them in and out to avoid detection from Audi?
    Jul 21 2004
    South Florida
    Quote Originally Posted by acidvoodoo View Post
    Not anymore. The ECU has immobilizer functions tying it to the VIN on the car. If you swap in a new ECU the car will not start. In order to clone the ECU to the VIN you need an SKC (secret key code) generated at the dealership. So you'd need a dealership to program each ECU each time you swap. The other way is for a high level tuner to remove immobilizer functions. This has been done but good luck getting it done without knowing someone.
    Mike
    2018 Audi S5
    Gone-
    Mar 11 2016
    Providence
    Mike
    Thanks for the info Mike
    Feb 05 2014
    Mike
    Thanks again for the infomation
    Established Member Two Rings LTopher's Avatar
    Oct 19 2017
    2001 Jeep GC; 2011 Jeep GC
    South Carolina
    Another vote for IE's tune. I went from stock to stage 2 (93 oct) and have been loving it. Very smooth power increase throughout low to high RPM range. If you catch one of their sales, you can get the stage 2 tune plus DIY cable for less than $600.
    Don't quite understand the logic here, though I see a LOT of posts saying the same thing. If you want to be conservative for longevity and reliability, wouldn't you just leave your car stock?
    To me, a conservative tune is like eating fat free ice cream--it will still get you fat, but will taste subpar. May as well get the regular ice cream and enjoy it or skip ice cream altogether.
    Senior Member Three Rings tominabox1's Avatar
    Nov 08 2017
    DFW
    Quote Originally Posted by LTopher View Post
    isn't APR more aggressive than IE??? From my research APR has the highest gains over stock (whether that translates to a noticeable difference is up for debate)
    I'm leaning towards IE stg 2 myself....
    2014 A4 Quattro // Sport Package, Black Optics, Bang and Olufsen
    IE Stage 2, CR-15 Strut Brace, USP High Flow Cat, Spulen turbo inlet pipe, aFe filter
    Mar 24 2014
    Quote Originally Posted by tominabox1 View Post
    Just about every stage 1 tune is similar in output.
