Results 1 to 12 of 12
    Veteran Member Four Rings ralphie_43's Avatar
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    JB4 vs. Stage 2 tune
    Which is a better option the jb4 or a stage 2 flash?
    Sent from my SM-G930V using Audizine mobile app
    Feb 11 2018
    Mooresville, NC
    Depends. A good flash tune is going to be a bit better. But a JB4 will not void your warranty if that's important.
    A proper map 6 JB4 will hold its own though - https://www.youtube.com/watch?v=LlbLW05n9uc
    '16 Q5 3.0T || Integrated Engineering stage 2 DP || Mercracing H/X || AFE filter || 034 inlet pipe || HP Tuners ZF8 tune
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    Agreed with Madmen...technically speaking, an ECU flash is better than a piggyback simply due to the total parameters which are accessed by a flash. However, with any stage 2 setup, a DP is required. Whether you're running Unitronic, APR, JB4, etc, you're splitting hairs at that level. It's not like one tune or piggyback unit is making substantially more power or putting bus lengths against another at that point. You'll just have to decide what's best for your needs.
    Youtube: The Automotive Fanatic
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    I was just going to chime in regarding location, specifically CA, when I saw OP is from Fillmore.
    The 335’s were big into JB4s and ran pretty well but not on 91, mine included. If you had access to 93 or a couple gallons of e85 it was much smoother.
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by theweebabyseamus View Post
    Hey yes I'm from Fillmore but not norcal, socal. I do have access to e85 but i think there's only one station near by but to run e85 wouldn't i need new fuel pump and injectors?
    Established Member Two Rings MathildaS3's Avatar
    Apr 14 2015
    Palm Beach Gardens, FL
    JB4/Audi will run fine on map 1 with 91. You could log a map 2 and send it to George @ BMS. He can help make a happy medium custom map (6).
    2016 Sepang Blue S3. MagRide, SuperSport seats, B&O, RS3 grille, wheel spacers 10mm/17.5mm, K&N drop-in filter, stock intake mod, LED interiors, Spulen engine mount insert (modified), BMS JB4 tune. Sleeper AF...
    Feb 09 2016
    Ct
    Are these JB1/4s really not t detectable by Audi? And are they really safe? I just came from the EB mustang world and there were a couple piggyback devices and they were all considered bad news. I guess because the ecu could not react to them since they didn’t communicate with each other. How is it different with the S3?
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by MathildaS3 View Post
    Ok cool i may do this or have a coworker whose a tuner tune it for me
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by marjen View Post
    Yes it doesnt flash the ecu only plugs into sensors
    Feb 11 2018
    Mooresville, NC
    You have to remove it for dealer visits (25 minutes). But since it doesn't flash the ECU, it doesn't trip the flash counter that VW looks for. The JB4 is a very advanced piggy back. It uses parameters from the O2 sensor and OBDII port to keep fuel in check. It's probably safer than a flash tune, since it uses all the OEM failsafes - as long as you don't try to force too much boost in the custom settings.
    The 335 JB4's are even better, as they have an auto learning map that adjusts itself based on octane levels and other parameters. So you don't have to worry about running 91 one week, and E30 the next. Hopefully they add that to the VW stuff some day.
    Oct 04 2017
    SFLA
    Yeah after the conversation i had with two Audi dealerships and a little prick that works in one of them. I’ll be going JB tune this time around. Funny that i come from VW and the dealership was sooo cool and mod friendly, makes me wonder if i should just get an R instead lol.
    Feb 11 2018
    Mooresville, NC
    Quote Originally Posted by speeddemon69 View Post
    The problem with a tune though is even if the VW dealer is mod friendly, VW corporate has to approve the repairs (on significant repairs anyway). They will connect to the ECU to check for a tune, which the dealer will have no control over.
