In preparation for subwoofer install, I thought I'd to some exploration and sound dampening in the rear of my 2018 A6. I have a few questions I thought some of you may have already contemplated:
- I am assuming that I'll benefit in terms of limiting resonance and minimizing road noise with a combination of a Dynamat-like product stuck to metal and a foam/vinyl combination (like SecondSkin Luxury Liner Pro, which I believe SubterFUSE used in his S6) above that; does anyone have experience to suggest this is over-kill?
- In order to remove trunk liner side panels, is it required to fold down rear seat AND remove side bolster of seat?
- If I need to remove seat side bolster, does the seat bottom need to be removed?
- If removing rear seat bottom, from what I've read, it seems clips likely break, are they "dealer only" parts; where's a good place to get diagrams and part numbers? For BMW I used "realoem" with great success.
- Any tips or warnings I should consider when removing the plastic trim panel at the rear most portion of the trunk opening?
Thanks in advance for your comments!
