Results 1 to 16 of 16
    Mar 12 2018
    Orange County, CA
    255/35/19 rubbing concerns
    I decided to put 255/35/19s on my front wheels. Here are some photos of the clearance.
    https://imgur.com/a/nxVDP
    The first photos are the wheels fully turned and there’s about a .5 inched of space on either side. At no turn there’s a couple inches. So far I see no rubbing but I’m wondering if I’m cutting it too close and if I hit a hard bump I may be in for some damage. Anybody else running these successfully? Also I have not lowered nor do I plan to.
    Here’s what they look like:
    https://imgur.com/a/l25Jt
    Mar 02 2018
    socal
    the consensus is avoid it, if you have people in the car you may rub and speed bumps may rub.
    Nov 06 2017
    Vancouver
    This opinion may not be popular, all rubbing issues aside:
    Having worked in the tire industry for about a decade at some point in my life, I really don't like messing with overall tire diameter. It is too critical of a standard that too many systems are based off of. Everything that reads and calculates off of the wheel speed sensor is affected - ABS, stability control, traction control, speedometer, odometer, and a bunch more. Overall gearing is mechanically affected as well. The AWD system is mainly concerned about difference between front and rear heights, but the OEM setup does have about 1/2" stagger height wise (shorter in front). There is always some wiggle room because tires don't always wear evenly, but by changing it you are intentionally getting yourself closer to the threshold where you will start to have issues. I'm just not a fan.
    Mar 12 2018
    Orange County, CA
    Quote Originally Posted by Potatohead_RS3 View Post
    But they run squared and staggered versions on this car so they've already planned for that setup in the engineering. That being said, I think I'm going to go back to a 255/30 front and keep the rears at 255/35 so i still have the same heights.
    Nov 06 2017
    Vancouver
    Quote Originally Posted by Pneub View Post
    Fair point. 255/35 is a fair bit taller though.
    I assume you mean 235/35 rear... Switch to 30 series front is what I would do.
    Mar 12 2018
    Orange County, CA
    The stock tires are 235/55 but I’m going to leave them at 255/35 and then swap the fronts back to 255/30. It’s not exactly stock but it’s close enough. Otherwise I’d have to find a way to sell these tires for a pretty big loss and this way I can hold onto the extra set of 255/35 and put them on the rears when the current tires start going out.
    Veteran Member Three Rings PeteJ's Avatar
    Jul 15 2013
    2017RS3-2014TTS-1967Olds442-2005Chevy2500HD-Duramax%2520
    Waukesha/wi
    I've been running them since November using my S4 Peelers, there has been no issue in the front and only a small issue in the passenger rear where the plastic lip on the rear of the fender mounts. I used a razor to nip off the little nub sticking into the wheel well and have had no issues....later today I'll be posting pics and starting a thread of my 275/30's I just test fit over the weekend ...
    https://www.529innovations.com/
    Finished #13 in One Lap of America 2019 #One0f250]
    https://www.facebook.com/2017RS3/
    The "Go Fast" Car.....
    369" of Oldsmobile power by Rocket Racing
    best of 9.68 @ 136 mph and a 1.242 60'
    http://mbworld.org/forums/signaturep...ic160318_1.gif
    Mar 12 2018
    Orange County, CA
    Quote Originally Posted by PeteJ View Post
    Thanks. I've been watching and so far no rubbing. Planning to keep my squared 255/35/19s unless something changes.
    Apr 04 2012
    2019 RS3 Ara Blu
    The 35 tall should be a better ride correct?
    Junior Member Two Rings
    Nov 18 2018
    Southern California
    When are guys are running the 255/35/19 up front, are you lowered? And how much camber are you getting? Currently I’m stock height with GC camber plates, but I’m still maxed on my front camber at -2.1.
    I’m trying to figure out how to get more camber. One thought is lower the car a bit, but since I daily drive it I don’t want it too low. So if I lower the springs but put on taller wheels up front I can get more camber without the front bumper being too low.
    Stage 2 Banner Advertiser Four Rings Kai@EliteMS's Avatar
    Mar 22 2011
    Lindenhurst NY - Long Island
    I run this size tire all around with a 12mm spacer as well, stock height. No rubbing.
    ELITE MOTORSPORTS
    21 W. SUNRISE HIGHWAY LINDENHURST NY 11757
    www.elitemotorsport.net - www.elitemotorgroupny.com
    P: 631.775.6634
    Follow Us On Facebook
    Follow Us On Instagram #elitemotorsports
    Follow Us On Twitter
    Nov 18 2018
    Southern California
    Quote Originally Posted by Kai@EliteMS View Post
    Ok cool, What’s your camber?
    Veteran Member Three Rings Flom Motorsports's Avatar
    Sep 18 2019
    Northern VA, USA
    Quote Originally Posted by Bryandanger View Post
    if it's any help, I'm running 265/30 on a 19" wheel. lowered on springs and the only rubbing I get is from my wheel fender arches touching the tires over big bumps at speed, but nothing a simple fender roll/pull can't solve. if the car wasn't lowered, i'd have no rubbing issues
    2018 RS3 - Too many mods to list them all
    2015 Q7 TDI - Daily and tow rig
    www.flommotorsports.com
    Nov 18 2018
    Southern California
    Quote Originally Posted by sirclass View Post
    Oh whoa. How much are you lowered?
    Sep 18 2019
    Northern VA, USA
    only about 1.3~1.5" on H&R springs
    Mar 22 2011
    Stock
    ELITE MOTORSPORTS
    P: 631.775.6634
