The reason for the switch is that I lost 2nd gear in the original O1E and reverse is very hard to access as well. This time however, I have the luxury of using a friend's lift that he has located in his "at home" garage. The thing that surprised me the most was that I seem to have a more difficult time seeing the upper bolts that hold the O1E to the 4.2 . I have Milltek Catless down pipes installed and it looks like I have enough clearance to drop the transmission without removing the pipes, comments, suggestions? I cant remember if I had to remove the down pipes the last time that I did this , but I think I'll give it a try. On the back half of the Milltek Catless exhaust, I had last used a pair of "platinum induced" mini-adapters , that screwed into the bungs and the O2 sensors screwed into them, fooling the O2 sensor into thinking it was a "real cat". I'd like to renew these units while I've got things apart, but my 63 year old brain can't remember who the supplier was. Anyone? I also just read something about adding a resistor in parallel with the O2 sensor to accomplish the same thing. Is this a better idea or is there something even newer out there that I haven't heard of yet? While I'm at it, I finally got the "RS6 knuckles" needed to complete the RS6 rear brake and caliper upgrade. This has been a long time coming as I originally did the fronts about 5 years ago. Wish me luck, Thank You, Paul, Providence, RI
