Results 1 to 16 of 16
Thread: Carbon cleaning
    Feb 17 2016
    Carbon cleaning
    Has anyone in the Puget Sound area (Everett to Tacoma, Seattle to snoqualmie) had carbon cleaning done and not get charged an arm and a leg? Any help would be appreciated
    Veteran Member Four Rings NaiveTurtle's Avatar
    May 20 2013
    Vancouver, WA
    Quote Originally Posted by stiggysaurus View Post
    DIY is really the only way around that. Even if you found an independent shop to do it by blasting with walnut shells you're still looking at 10-14 hours ($1,000-$1,400).
    2008 GMG World Challenge 6MT []S5 Ibis White Matte Metallic Purple/Black Alcantara
    [Mods - GIAC 91 Tune | GMG WC Sport Downpipes | GMG WC Sport Cat-Back | GMG WC Front & Rear Sway Bars | AP Racing 6-Piston Front BBK | 20x9.5 HRE P40's | Accuair B8 Sport Kit]
    2004 Ocean Blue Metallic A4 Avant
    Instagram: @NaiveTurtle
    Veteran Member Three Rings AvusPdx's Avatar
    Jan 17 2015
    Portland, OR
    God DIYing a CC would be a nightmare. I've shopped around for it, and the price was all over the place, but shouldn't pay more than $850 for it.
    I have a good relation with a local shop and did CC/Spark Plugs/oil change (rs4) for $1000 out the door.
    Carbon Buildup affects power but should be okay for daily driving. Just as a reference, I gained 50whp on the same dyno after a CC.
    Current - Audi B8.5 S4 2013, Mercedes Benz GLE350 2016, Volvo XC60 T5 2015
    Mods - H&R RSS Clubsport, APR stage 2 + pulley, Roc Euro intake, AWE Touring 90mm, ECS RS4 Gloss Black Grill, VMR V705 19x8.5 matte black, Blizzak LM32 225/40/19 (winter) OEM Q5 Peelers 20x8.5 et33, Dunlop Sportmaxx 245/35/20, EBC Slotted/Drilled rotors F/R, EBC redstuff brake pads, Motul RBF 600 brake fluid, Enlaes rear CF spoiler, LED interior light swap, LED fogs, H&R rear sways,
    May 20 2013
    Vancouver, WA
    Quote Originally Posted by AvusPdx View Post
    DIY'ing a carbon cleaning is not that bad. I did it to my S5 like two years ago. It is very time consuming but very doable.
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    If you have the head off its much better. Idk what forum im in but this was on a 2.0t.. Lots of brake cleaner and little flat head screwdrivers.
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    May 20 2013
    Vancouver, WA
    Quote Originally Posted by Solarsuplex View Post
    Definitely does not require a head pull but I could see how it would be easier.
    I did my 4.2 V8 in the car and the only issue was being bent over for hours. Definitely used a lot of brake cleaner and dental tools for scraping.
    Aug 20 2011
    Seattle Wa
    Quote Originally Posted by NaiveTurtle View Post
    Just being off the car and on a bench with proper lighting really helps. Plus you don’t have any about shit falling into the cylinders
    -James
    Feb 17 2016
    unfortunately i don't have a parking space let alone a garage to do a DIY. I have a 2.0T that has about 45k miles.. the fuel economy is pretty bad but idk if I should chalk that up to having a roof cargo box (although it's one of the more sleek and slim boxes)
    Veteran Member Three Rings Low and Behold's Avatar
    Feb 21 2015
    Rip City
    Whats "pretty bad" fuel economy? There can be many ways to fix bad fuel economy without doing a full blown carbon clean. Roof box isn't going to make a measurable difference
    Casey | @cshore | B7 A4 Avant 2.0T | B8 Q5 2.0T
    Feb 17 2016
    Quote Originally Posted by Low and Behold View Post
    The DIS says about 18.5mpg and I do about 50/50 city/hwy split. According to Google the car is rated 20 city 27 hwy.. car is stock minus a drop in air filter and I'm driving aggressively in any way. I even pumped the tires 3mpg over recommended to try and squeeze out a bit more efficiency. Any thoughts would be greatly appreciated
    Feb 21 2015
    Rip City
    I think the best way to measure mpg is gonna be the old fashioned way - fill up and set your trip odometer, check on the next fill up. Things to check:
    Fuel filter
    Air filter
    Plugs
    PCV
    Maybe run a fuel system cleaner like BG44k
    What fuel are you filling up with?
    Feb 17 2016
    Fuel filter
    Air filter
    Plugs
    PCV
    Hmm tbh idk how to check the fuel filter or PCV but I had dealer do new plugs at 35k and the air filter is less than a year old but it may be a good idea to check it out. I’m using 92 oct from Costco
    Feb 21 2015
    Rip City
    Fuel filter you can't really check - but they're $50 and super easy to change. Search the forums for PCV stuff
    I filled up this morning and calculated my MPG.... 16mpg, which tbh for me is pretty average. And I've changed everything over the years. Also did a carbon clean.
    b7 2.0
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Audizine
    Just ordered a couple bottles on Amazon (1 for my Audi and 1 for our Tahoe). This stuff work? Lots of positive reviews on Amazon.
    Feb 21 2015
    Rip City
    I didn't notice a huge difference when I used it last. But you might!
    Considering my own horrible gas mileage, i should probably try it again. Or just continue to live with it :(
    Senior Member Three Rings studiobmx's Avatar
    Jun 20 2016
    1.8T Vanagon, B7 Avant, C5 Allroad, NCV3 Sprinter, Q5 (wife's), CB550
    Tacoma
    I live in Tacoma and did mine. It was actually pretty easy.
