Originally Posted by
dalmation53
It needs to be done anyways. If it hasn't been done thats why i said "maintenance" did you not read? All the things i said fail on this cars or tell me i'm actually wrong?
Sent from my G3313 using
Audizine mobile app
While you are right, all of these mainenence parts are a great idea on a car that runs right, it probably won’t do anything to FIX his problem. What’s the point of a throwing preventative maintence parts on a car that doesn’t run right unless it is directly related to the fault? Do you not see that it’s just like telling someone to replace their coil packs because their transmission is slipping? Or it’s like this, what’s the point of throwing in a new air filter if he needs a new clutch?
Don’t be so quick to spend other people’s money when they are asking for help is all I’m saying. He’s already probably spent a grand and he’s nowhere near solving the problem. Diagnosis is a process. You have to work the steps before you start replacing parts and all the new coil packs in the world aren’t going to fix a lean code.
He doesn’t need preventative maintenance right now. He needs a specific solution. And in case you haven’t noticed, I can read and communicate words pretty well actually.
