Results 1 to 18 of 18
    Established Member Two Rings mp33dave's Avatar
    Apr 03 2012
    12' A6
    Midlothian, VA
    Coolant / High temp issues
    So just the other day my 12' A6 decided that the temp gauge wanted to show almost maxed out HOT. I thought that maybe it was some air in the system because 3 months ago I did replace the Valve for Transmission Fluid Cooler b/c of a CEL P2753. After that install all worked fined - no more CEL and high temp on the gauge never happened. Scanned the car and got a MIL Request Signal Active (Check TCM for errors too!) P1624 code as well.
    So I drained all the coolant that I could from the drain screw under the car...I was able to replenish the G12 mixed with distilled H2O with just over a gallon of fresh fluid and bled the system to get all the air out. So this AM I went on a 15 mile ride - mixed highway and in town and not a single issue. Temp gauge was perfect. Parked for about an hour and headed back on the same return trip and about 2/3 way through it started to climb up to almost maxed out high - then fans kicked in and the temp started to slowly come down. If I cranked on the heat it would also come down a bit...but the fans would run high and loud. I'm thinking about changing out the coolant temp sensor and the engine temp sensor. Hoping its not the water pump or thermostat.
    Any other ideas outside of what I have done or think it might be?
    Senior Member Three Rings GlacierS5's Avatar
    Jul 27 2017
    San Jose, CA.
    Sounds like the thermostat
    Sent from my SAMSUNG-SM-T337A using Audizine mobile app
    2018 Glacier White S5 | Prestige | Sports Pkg | Dynamic Steering | Carbon Fiber Pkg | 034 Motorsports Parts
    2016 Sepang Blue RS7 | Prestige | SRM Intake |EuroCode Sways
    2014 Glacier White S6 - SOLD
    Apr 03 2012
    12' A6
    Midlothian, VA
    yeah - I'm hoping it's not the thermostat - i really don't want to take off the supercharger.
    Nov 21 2017
    Layton, UT
    Did you ever get this figured out? Having similar issue with my A6. Temp guage rising after driving for about 20-25 minutes, running the heater will bring the temp down as well. Coolant was low and dealer replaced fluid after doing an oil change. Still was overheating, so took it back, this time they found Fan 1 fuse had blown $425 later, still getting temp issues.
    Established Member Two Rings Mr_Nachi's Avatar
    Mar 09 2018
    Sicklerville, NJ
    just went through this thermostat was staying closed... literally wrapping up today and hoping to enjoy a drive with out the car heating up.. will be monitoring via the vcds later tonight....
    12' Audi A7 Prestige w/ Sport Package
    RS7 gloss Black Honey comb Grill
    Blacked out emblems
    H&R Lowering Springs
    5% Tint
    Magna-Flow Catback Exhaust
    Roc-Euro Intake and Heat Shield
    Custom Stage 2 Tune (currently running 17 PSI)
    CTS supercharger & Crank Dual Pulley setup
    Nov 21 2017
    Layton, UT
    Quote Originally Posted by Mr_Nachi View Post
    Bummer. What was your total for that? Still more than $2k? I really don't want to have to do that. May try this on my own, not a lot of places I trust to work on any car let alone my new (to me anyway) A6.
    Mar 09 2018
    Sicklerville, NJ
    Quote Originally Posted by SmittyR6 View Post
    $2,341 plus tax at the stealership (thermostat and water pump)
    Blacked out emblems
    5% Tint
    Veteran Member Four Rings nefkntym's Avatar
    Jan 30 2007
    a bunch of tools
    Monument, CO
    Not sure about the supercharged models, but the with the V8s, if the coolant gets too low either through draining or a leak the heater core has to be bled as well when refilling because air gets trapped due to the low fluid level.
    2023 Q7 - Ibis White
    2024 SQ8 - Chili Red
    So many have come and gone…
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    The thermostat is a known issue on these early C7 3.0T engines. Mine failed and left me stranded in Shoshone CA for 13 hours while I waited for a flat bed tow truck. If yours has not been replaced than I would suggest having it replaced before it fails completely. The replacement is a newer version with an aluminum housing instead of a plastic housing.
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Mar 09 2018
    Sicklerville, NJ
    Anyone know the part number to the part the superseded the old one? I want to make sure I got the upgraded one from the Dealer
    Blacked out emblems
    5% Tint
    Oct 11 2011
    2018 A5 SB
    The P/N of the thermostat assembly used when it was replaced in my is A6 is 06E-121-111-AL. I hope this helps.
    May 11 2018
    prius, Roadtrek,
    San Diego
    Whoa... so replace the thermostat which leads to the water pump etc ? and 2 bills plus. What years are the early suspect years? I have 2016 well 2015 in non audi years. Thanks all!
    Kurt in Sunny San Diego 2016 A7 Moonlight Blue, Flint Grey Interior, , 034 rear sway bar and upgraded links front and back, deleted middle muffler, ,Hartmann RS7 copy wheels, RS 7 grill. puddle lites. debadged, EPL Stage 1 TCU tune and APR Stage 1 ECU tune, Ceramic coating, tinted windows
    Oct 11 2011
    2018 A5 SB
    Quote Originally Posted by DiegoKid007 View Post
    I believe you should be fine.
    Junior Member Two Rings
    Nov 21 2016
    North Hollywood
    I have a 2012 A6 3.0T and recently had a coolant leak but my temp gauge never went up, took it into my independent shop to see what the cause was. They reported back that my thermostat was getting stuck, one of the pipes for the coolant system was brittle and leaking as well. Had it all replaced for about $2300.
    They also noted that my passenger side fan was no longer working.
    So I took the car into Keyes Audi today for the POD recall (if you're an LA resident) and they did a health check as usual and now say that my fans are completely bad (temp gauge still has not went up) and that my water pump needs replaced.
    No idea what's going on and what really needs fixed but I think if we all complain to AOA we can get a recall on this coolant system as a whole.
    I'm so tired of putting money into this out of warranty car.
    May show my health report so you all can see how much needs replaced on this car now
    Established Member Two Rings Tman007's Avatar
    Apr 27 2014
    Space Coast, FL
    Sorry to revive a slightly old thread, but I found this thread to contain some very valuable tidbits...
    For replacing both the water pump and thermostat, do you guys recall how many hours of labor that took? I'm just trying to do a sanity check on an indy estimate I got for 3.5 hours of labor for just the water pump replacement, or 6 hours of labor for both water pump and thermostat. Does that sound about right?
    2012 A7 Prestige
    Quartz Gray / 20" Sport / Bose sound / Ventilated seats / Cold weather pkg / Innovation pkg (LED / Night vision / HUD / ACC / Side assist)
    Upgrades: Xpel Ultimate full front / RS7 steering wheel / RS shift knob / MMI v814 / Matte Ash trim retrofitted / Akebono ceramic brakes
    Equip: Escort 9500ix radar / Escort Live iPhone hardwired / Mobius v3 dashcam hardwired
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by Tman007 View Post
    I had my water pump and thermostat replaced on my SQ5 (same 3.0T motor).
    $237 parts, $640 labor for the water pump (so maybe 4 hours @$160/hr)
    I was quoted $1150 to replace the thermostat as they have to remove the supercharger. It is only an $80 part so it is a massive labor cost. If I was going to have them undertake it I might ask them to replace anything else under there that looks like it might need replacing. PCV/oil separator and PCV shutoff valve come to mind.
    In my opinion 6 hours for both sounds like a relative bargain I'd think 4 for the pump and about 6 for the thermostat (10 total).
    What was their total quote?
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Apr 27 2014
    Space Coast, FL
    Quote Originally Posted by gk1 View Post
    Thanks for your insights. Good point about doing the oil separator etc as well, my guess is that wouldn't be too much more work.
    Total quote was around $700 for water pump replacement, or $1300 for both water pump and thermostat. (Labor costs are lower here in FL.)
    Anybody else have any thoughts on the number of hours for these jobs?
    2012 A7 Prestige
    Apr 27 2014
    Space Coast, FL
    Got a quote for replacing the PCV/oil separator and PCV connector at the same time as the above job. $180 parts and 0.5 hr labor, so it's a no-brainer to get it done at the same time.
    2012 A7 Prestige
