Results 1 to 19 of 19
    Established Member Two Rings ECP's Avatar
    Oct 13 2014
    Any other big HP s3’s floating around?
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    There are some people running aprs stage 3 and some people running IROZ turbokits. What is that S3 on the dyno running?
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Oct 13 2014
    Quote Originally Posted by S3DUDE View Post
    Iroz 780
    Nov 17 2014
    San Francisco, CA
    I have a hybrid on my a3, but nowhere near those numbers. #400club but shooting to be closer to 500 on e85. Currently just cleaning up the bugs.
    Is that S3 on stock internals running those numbers? If so...insane!
    Sent from my Pixel 2 XL using Tapatalk
    Oct 13 2014
    Quote Originally Posted by mroberte View Post
    Built motor.
    Who are you using for tuning/ethanol etc
    Nov 17 2014
    San Francisco, CA
    Quote Originally Posted by ECP View Post
    Built motor.
    Custom tuned by mabo, but ethanol analyzer by fuel-it and waiting for some additional fueling kits to hit the market.
    Veteran Member Four Rings aaron1085's Avatar
    Jul 12 2007
    2007 2.0T A4
    NH
    So forged internals and port and polish makes this ‘built motor’ correct? Just checking myself here. Amazing numbers and such a small car ... imagine if it lost a few pounds and with some suspension mods. Lights out.
    "The important thing is not to stop questioning. -Albert Einstein"
    "Treat everyone like a million bucks; and always have a plan to kill them"
    2007 A4: APR, STaSIS/Alcon, Avant Garde, Hankook, Ohlins
    Oct 13 2014
    Quote Originally Posted by aaron1085 View Post
    Yes
    Your avatar pic, is that a seadoo??
    Veteran Member Four Rings 613B6's Avatar
    Jul 29 2009
    Street racing in Ottawa
    Amazing numbers! But it sucks your DSG will explode at that level. The Iroz cars are getting some flack lately, posting great numbers and under performing at the track.
    A3 8V | 10.89@129 | Boss700 | Eurodyne
    May 05 2014
    F80 M3
    Angry
    Quote Originally Posted by 613B6 View Post
    Have you seen the numbers APR stage 3+ are running?
    Jul 29 2009
    Quote Originally Posted by P2WRTMR View Post
    Yes, what are you asking?
    May 05 2014
    F80 M3
    Just asking since you mention underperforming.
    Jul 29 2009
    There are a pile of APR cars on stock motors running mid to high 10s, very impressive. The OP car before these numbers I believe ran 10.4 ish with a built motor and much more power than APR stage 3+ cars, just seems to be a common trend unfortunately, dyno numbers are just that though. How fast does your dyno trap :P
    Oct 13 2014
    Correct, 10.4@136 before making a few changes which you see above.
    I was stg3+ but bent a rod which wiped out the block. Went a different route since all apart.
    I’m hoping for 140+ trap in a 3500lb car 🤞🏻
    Jul 29 2009
    You should see 145 with that power, Ill say a prayer for your tranny :) Best of luck and keep us updated!
    Oct 13 2014
    You and I both on that prayer
    Veteran Member Three Rings jiannu's Avatar
    Mar 23 2016
    Ontario,Canada
    You spent all that $$$$ you should at least upgrade to a DQ500. Then you should be golden!
    Oct 13 2014
    Quote Originally Posted by jiannu View Post
    I’m curious what makes you think a dq500 is any better?
    Jul 29 2009
    Its rated from the factory for much higher tq levels, so we assume the internal strength is greater. I think it was developed for the VW Transporter Vans before being put in the RS models, plus you get the added 7 speed gear set. I shredded a few gears and bearings in my DQ250 equipped, 500whp MK5 GTi, great transmissions but they only can take so much.
