Originally Posted by
funkypterodacty
Jhm flywheel uses an RS4 clutch disk and pressure plate so their R series clutch should bolt right up.
The R disc I believe requires them to modify likely the flywheel as the plate depth is slightly different from OEM style to ACT style pressure plate. I measured some stuff when I had that pressure plate in my hand wanting to install it but at that time they were still developing and wouldn’t feed me the info so I could have just had the work done myself then installed it. They I know for a fact wanted to add the JHM R setup to the A4 plateform as power goes up.
My car
034 2.0T aluminum flywheel $525
RS4 stage 4 disc (from the jhm R RS4 kit) $700
JHM BLACK pressure plate
This too
Metal MASTER cylinder (yes on the peddle)
Metal SLAVE cylinder
Steel braided line.
