Results 1 to 7 of 7
Thread: Can I go WIDER?
    Veteran Member Four Rings maty360414's Avatar
    Oct 13 2015
    SoFlo
    Thumbs up Can I go WIDER?
    That is 12mm on front and back, will a 15mm front and back make it flush? Or 15 and 20 what do you guys recommend just installed H&R Super Sport Springs
    1st picture back
    2nd picture front
    '13 S4 | EPL DP E40 | EPL TCU | AEM W/M | Tampa Ported S/C | 75mm TB | JHM 187 | MercRacing HX/Divorced | Becker TestPipes | AutoTech HPFP | Roc Euro Intake | BFI Engine Mounts | ECS Trans Mount | ECS F/R Diff Mount | H&R Super Sport Springs | 034 Rear Sway Bar | CR-15 | Drilled & Slotted Rotors | StopTech SS | Vertini RF 1.3 | Indy 500 | Sport Diff | BFI Shift Knob | Quattro Grill | ECS Spoiler/Diffuser | RS4 Bumper | J-Code | CWA100 |
    Senior Member Three Rings Roaldtm's Avatar
    Jul 20 2014
    Martinez / Georgia
    Quote Originally Posted by maty360414 View Post
    Love your car! What you did to turn the chrome trim black?
    Sent from my SM-G960U using Tapatalk
    Oct 13 2015
    SoFlo
    Quote Originally Posted by Roaldtm View Post
    Thank You :), i used Plasti-Dip :P
    Veteran Member Three Rings AvusPdx's Avatar
    Jan 17 2015
    Portland, OR
    We have entered, event horizon.
    Current - Audi B8.5 S4 2013, Mercedes Benz GLE350 2016, Volvo XC60 T5 2015
    Mods - H&R RSS Clubsport, APR stage 2 + pulley, Roc Euro intake, AWE Touring 90mm, ECS RS4 Gloss Black Grill, VMR V705 19x8.5 matte black, Blizzak LM32 225/40/19 (winter) OEM Q5 Peelers 20x8.5 et33, Dunlop Sportmaxx 245/35/20, EBC Slotted/Drilled rotors F/R, EBC redstuff brake pads, Motul RBF 600 brake fluid, Enlaes rear CF spoiler, LED interior light swap, LED fogs, H&R rear sways,
    Oct 27 2015
    San Diego, CA
    Did you remove the trim to do it?
    2019 RS5 Sportback - Navarra Blue
    Registered User Three Rings AutoTalent's Avatar
    Apr 24 2015
    Quote Originally Posted by SDBolts View Post
    You can just mask off the areas you don't want plasti-dip to go on. Even if it goes on somewhere else it's super easy to remove.
    Senior Member Two Rings hamzahj's Avatar
    May 05 2017
    Knoxville, TN
    Can I go WIDER?
    That looks pretty flush to me, unless you want the tires to stick out a bit. I’m running 20mm in the back but not too sure how comparable an s5 and 4 are in this regard
