I'm going to be writing a review soon on the Stx coilovers I just installed a few hundred miles ago but I will chime in here a bit for now...
The STs are absolutely perfect for the street. The spring rate is still conservative.
The car does everything better and the ride quality is also better 90% of the time in my opinion.
I have found most coilovers are typically aggressive and one thing I dislike usually is the bouncy feel they sometimes create on the highway because they are so stiff.
The STs on the highway are absolutely butter smooth and I find them even better than stock on the highway because they have less movement yet still have enough compression for the Minor Road imperfections to not be noticeable.
They handle significantly better than stock all around. There is still minimal body roll and if you track your car frequently they will probably feel too soft. If you don't mind a harsher ride and want no body roll at all you should look into a stiffer setup.
Because I have my GTO which is set up real aggressive with very stiff spring rates etc... and my A3 is my daily driver these St coilovers are exactly what I wanted for my car.
I hated the fact that I could stick my entire fist between the tire and Fender on the stock suspension. That was my main reason for getting them, I also have a stage 1 tune and felt I was overpowering the stock suspension significantly. I also have adjustable dampers on my GTO and have never adjusted them after I put them where I like them so I didn't care about that feature.
Let me know if you have any questions
Sent from my SM-N950U using
Audizine mobile app
