Results 1 to 22 of 22
    Feb 17 2004
    Liberty Hill, TX
    **SOLD** Custom Brushed trim Auto Headlight Switch
    After scouring the forums here and finding no good option for a headlight switch to match the aluminum trimmed window/mirror switches which are available for our cars, I set out to build my own. I ended up having enough usable parts for two switches, so selling the extra.
    This switch uses the internals and trim ring from an OEM headlight switch, along with the center section from an aftermarket MKIV switch (which are not available in an auto version which is compatible with the B6/B7). The center section has been modified to sit flush with the trim ring, rather than 1mm recessed (as the MKIV switch itself is slightly shorter / sits slightly further inward). Because of this, the normal "push/turn" unlock mechanism does not work, but the tab can be released via access from the fuse panel.
    Switch is built from new parts and is cosmetically perfect with the exception of one scuff on the trim ring which is not visible when installed (and has been touched up). The trim on the center section is aluminum (silver), not chrome like many of the cheaper/eBay switches use.
    Asking for my cost in materials plus shipping, which works out to $100 shipped.
    **SOLD**
    cheers,
    Matt
    2012 TT-RS | Sepang/Ebony
    2014 Allroad | Glacier/Ebony (sold and bought back)
    Sold: 2007 RS4 | Sprint/Ebony
    Senior Member Two Rings flavormonkey's Avatar
    May 14 2015
    RS4 Avus
    United States
    Nice work. I'll grab it from you! Pm me your email?
    Sent from my SM-G935V using Tapatalk
    IG: @Blu_Fin_RS4 - @flavormonkey - @chakrascience
    May 14 2015
    RS4 Avus
    United States
    Received andlooks 👌👌👌👌
    Feb 17 2004
    Liberty Hill, TX
    I've been building these to order for a lot of fellow RS4 owners, and have a few left over currently. These are brand new OEM switches, with a custom center section, and modified for independent front fog lights (lets you run fogs with parking lights) when coded appropriately via VCDS. $125 shipped ea
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    These are great quality! Bought one myself
    Jan 23 2014
    '13 Touareg TDI - '08 RS4 Mug/Ti
    Derby City
    Do you have any without the brushed center? That would look a bit our of place in my RS4 which only has the pedals and shift knob like that.. Thanks
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by 87vr6 View Post
    the brushed center is the whole point of the switch, if you don't care for that, then just buy a new OEM switch. Many RS4 owners (like myself) have replaced the window/mirror switches with brushed trimmed ones, so the brushed headlight switch complements that perfectly and completes the look
    Aug 02 2015
    Corning NY
    Correct! Update the interior! Lol
    Veteran Member Three Rings outsider6661's Avatar
    Jul 02 2007
    2008 RS4, 2016 S5 Black Optics
    Markham Ontario, Canada
    Do you still have any of these available? If so I'll gladly perches one from you!
    Sent from my SM-G950W using Tapatalk
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by outsider6661 View Post
    sent you a PM
    Jan 23 2014
    Derby City
    I was mainly after the independent fogs thing.. I'll look up how to DIY then
    Quote Originally Posted by Pyromatic177 View Post
    Ha. Update.. Riiiggght.
    Veteran Member Four Rings eurojunkjon's Avatar
    Mar 12 2017
    2013 S4
    Burlington, wi
    installed mine today thanks Matt
    Veteran Member Three Rings my_RS4's Avatar
    Apr 15 2016
    Beach Cruiser
    Venice
    Quote Originally Posted by eurojunkjon View Post
    Looks great!!
    IG @myRS4 | 2007 RS4 | Phantom Black | Ti Converted | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed + Citied + CC'd | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | JHM Lighweight Flywheeled | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
    Established Member Two Rings Codiac's Avatar
    Apr 26 2011
    B7 S4
    Purchased mine a few months ago from Matt, its absolutely worth it!
    Veteran Member Three Rings .Koby.'s Avatar
    Jun 26 2012
    Do you still make these?
    2007 Audi RS4 - Mugello Blue
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by .Koby. View Post
    yes, built to order, shoot me a PM
    Oct 28 2018
    Chicago / Winnetka
    Still making them? I may need to replace my switch anyway.
    Out of curiosity, is this still part #8E0941531B5PR
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by Spazdoc View Post
    I am still building them to order, now using brand new OEM switches. I have the -D part in stock, I'd check your existing part and if it's something else then I'd have to order it. Shoot me a PM and we can iron out the details
    Veteran Member Three Rings Flygman's Avatar
    Jan 27 2018
    Gothenburg
    Current:
    A4 B7 DTM | BSR Stage 1 | CTS HFC | Simons catback | 034 HPFP internals | K&N panel filter | Garrett FMIC | DO88 intercooler piping & hoses | GFB DV+ | IE PCV Delete | Poly snub mount, rear wishbone & spindle bushings | B5 'lowering perches' | Judd T325 19x8.5 ET32 rear + ET35 front | Pirelli P-Zero 235/35R19 |
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
    Senior Member Three Rings a.four's Avatar
    Jun 09 2019
    2023 Jeep Wrangler
    Know this thread is a few years old but can you still make one for a non-auto? Mine just gave out.
    Veteran Member Four Rings Ozone510's Avatar
    Feb 15 2016
    Audi A4 B8 Avant 2.0T, Audi A4 B7 2.0T SOLD, Audi TT 8J Cabriolet VR6 DSG
    Hayward, California, USA
    Quote Originally Posted by a.four View Post
    If you get auto, it'll work as your car has the required hardware already installed minus the switch!
    Garage:
    Audi A4 B6 6MT 2.0T Stroker F21L
    Audi A4 Avant B8 2.0T
    Audi A6 Avant C6.5 3.0T
    Jun 09 2019
    2023 Jeep Wrangler
    Quote Originally Posted by Ozone510 View Post
    Garage:
    Are you talking about an OEM part or this mod? I was only interested in this for the aluminum trim.
