Page 20 of 57 FirstFirst ... 10181920212230 ... LastLast
Results 761 to 800 of 2251
  1. #761
    Nov 26 2018
    The shop that'll be doing the work told me they usually inspect the guides before swapping them out, if they aren't worn or brittle they leave them in. They'll also be checking for the cam bridge screen and will replace the cam bridge if it is missing. I'm thinking of telling them to remove it if it's still in there and let the oil filter pick up the slack so that I have one less thing to worry about.
    I spoke to an ex Audi master tech yesterday that now runs his own business and he told me -4 to -6 is where failures start to happen in his personal experience, and recommended I get the chain and tensioner swapped out before reaching that point.
    2013 B8.5 A4 Quattro 6MT | 034Motorsports HFC | IE Stage 2 Tune
  2. #762
    Veteran Member Three Rings Chillaxin's Avatar
    Mar 28 2018
    Jacksonville FL
    I had a service manager at an Audi Dealer tell me that they just remove the screen if they find it broken when removing the bridge. It is a costly part to replace. Make sure they remove the black plastic section as well as account for the rest of the screen if it has failed. When I did mine, I found the screen had failed and used a pick to remove the rest of the screen section from the bore.
  3. #763
    Jun 27 2011
    Another Audi tech replied in here a year or so back and stated they also just remove the screen and leave the bridge as is. The bridge itself is expensive so it makes sense I guess. I replaced the bridge because I wasn’t aware that the screen could just be removed and mine was blown out and resting on the check ball. I bought the new bridge ahead of time just in case (and was going to return it if it wasn’t needed) but I figured better safe than sorry and just installed the new one. My mistake was tossing the old one in the trash. Whoops...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
  4. #764
    Veteran Member Four Rings mtroxel's Avatar
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by Chillaxin View Post
    My screen was gone. I just put the bridge back on w/o the screen. That was over 40,000 miles ago.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
  5. #765
    Feb 15 2016
    Cambridge,Ontario
    Dude that's garage art !!
    Sent from my SM-G973W using Audizine mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
  6. #766
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by mtroxel View Post
    Me too.
    1976 Yamaha XS 360
  7. #767
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by snaky69 View Post
    I would agree for cars on the old tensioner. At Those numbers the tensioner has to work harder.
    1976 Yamaha XS 360
  8. #768
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    So with the updated tensioner - is it less important to replace it preemptively? Meaning - for B8.5 could you just wait for chain rattle or codes before replacing the chain setup (chain, tensioner, guides)? Since the chain stretch should be very gradual, and the tensioner is not a likely failure point.
  9. #769
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by audrobotic View Post
    I don't think I would wait for chain rattle.
    I was asking the other day looking for a new style tensioner that failed.
    But I would not panic at 5
    1976 Yamaha XS 360
  10. #770
    Nov 26 2018
    Just a quick follow up, timing has been done, all guides were nice and clean, I had the new tensioner but the old chain.
    Tensioner was not all the way out, it was on the 9th detent so nearly all the way out. I did not think to grab a pic, sorry about that.
    Cam bridge was fine, screen intact with no signs of failurre.
    Also had two shocks and springs done with 4 wheel alignement, because one coil had broken in half in the middle.
    So yeah, expensive bill. At least I'm set for a bit.
    Will try and plug back into the car to update on the cam phaser numbers.
  11. #771
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Maybe I missed it but what is the mileage on your engine?
  12. #772
    Nov 26 2018
    143 000km.
  13. #773
    Dec 28 2006
    Western Maryland
    Thanks. It gives me an idea as to what to look forward to. I also have a 2013 B8.5 6MT (CAEB) engine.
    Some previous data points on mine:
    45,000 miles: -2.26° 7th notch
    55,000 miles: -2.46° 7th notch
    60,000 miles: -2.55° 7th notch
  14. #774
    Mar 08 2019
    MA
    ^ I'm at 4.7 at 110,000 miles so it seems like a 2.7 around 60k seems right. These chains definitely stretch with mileage.
    2013 allroad Glacier White/Black Sport. Many Mods.
  15. #775
    Established Member Two Rings YotoWerks's Avatar
    Feb 08 2018
    JSW TDI, 2010 XC90 V8, 2008 XC90 V8, 2009 XC90 V8 and 2005 XC90 V8 oh and Chrysler 200S
    Rochester Hills MI
    I finally got to check my 2013 with the VAG COM, im at 101k with 3.14° and the motor has never been opened. I guess ill let her go another 20-30k before I go replacing parts.
    2013 B8.5 A4 Quattro ZF, E85-APR Stage 2, IE DP, S4 Brakes Ibis White.
    2010 Volvo XC90 V8 R-Design, Custom Exhaust, Bremobo brakes 330mm/all 4.
  16. #776
    Feb 03 2017
    NH
    I'm at -4.6 on my 2013 CPMA with 76k.
    2013 A4 Premium - [ Exhaust tips / Rubber Floor Mats ] APR Stage 2 | CR-15 | ECS Luft Technik | 034 HFC |
  17. #777
    Mar 08 2019
    MA
    Quote Originally Posted by twixinthemix View Post
    Weird we're about the same (4.7). We have pretty much the same power mod and my car has been tuned forever. I don't get it.
  18. #778
    Dec 25 2019
    2009 Nissan Maxima SV, 2005 Honda Odyssey EXL-R&N
    Cheshire, CT
    Quote Originally Posted by Chatchie View Post
    Whats your engine code? I have dealt with two CPMA engines, and they both seemed to have excessive phase adjustment. I wonder if different engines
    do it at different rates due to internal design modifications.
  19. #779
    Jun 27 2011
    I think it has a lot to do with what sort of driving you do. Lots of cold starts from short trips, stop and go vs highway miles, etc.
    My old Q5 was very well taken care of, was totally stock and had the new tensioner from the factory (2012 CAEB) but was at -7° at 65k miles (or whatever it was that I replaced it at, it’s been a few years). I’ve seen plenty of cars with half that phase adjustment at the same or more miles. I also had the cam bridge screen blow out so that was worrisome, but I don’t think the car was abused in any way. It’s possible the previous owner pushed oil changes past 10k but there’s no way to know and there wasn’t really any damage to the guides that would indicate excessive wear.
    I think it’s just chain wear/stretch from tons of stop/start cycles. I believe the ECU logs start cycles, would be interesting to chart those with wear and see if any patterns emerge.
    -CP
    2017 Q7 3.0t
  20. #780
    Apr 10 2019
    Do you think it is routine start-stops or maybe the "jump on it" type of start that does the extra wear due to the higher dynamic loading? Maybe that degree of loading is not routinely tested by Audi (hard to do).
    Definitely cold weather/short trips -> water in oil can contribute to wear. Th Owners manual hints but does not prescribe like some other brands like Toyota that the interval must be reduced a recommended amoint.
  21. #781
    Active Member One Ring Wartowski's Avatar
    Apr 08 2017
    Earth
    Quote Originally Posted by Wartowski View Post
    My vcds show information like this after 30 mins normal traffic drive, how is it look? I have A4 b8.5 160k km. Oem chain and tensioner as I know. Why those 2 information degrees is my car 15.x and other have 28.xxx?
    I have newer car but same engine and results are:
    Engine speed: 804 /min
    Camshaft adjustment intake bank 1 specified 15.0°
    Camshaft adjustment intake bank 1 actual 14.9°
    Camshaft adaptation intake bank 1 phase position 0.7°
    Coolant temperature at engine start 81.0 °C
    Calculated oil temperature 78.0 °C
    1.8 tfsi, 92k km, motor code: CJEB
    B8.5 1.8tfsiq cjeb
  22. #782
    Dec 28 2006
    Western Maryland
    I don't think you can compare the 1.8T to the 2.0T. Obviously the 1.8T camshaft specified adjustment is quite a few degrees less than on the 2.0T. With that being said, I would think a low adaptation value would be a good thing regardless of the engine.
  23. #783
    Aug 21 2019
    Montreal, Canada
    Exact same for me.
  24. #784
    Junior Member Two Rings
    Jan 18 2018
    St.louis Mo
    Just checked mine today after my drive home from work. -5.67 degrees. I have 121,199 miles on my car. And it has a newer style tensioner on it.
    I’m going to be replace it of course. Are people also replacing the balancer chain, guides and tensioner as well?
    It’s a CAEB engine
  25. #785
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Nandor69 View Post
    It’s a CAEB engine
    Yup.you fit the curve perfectly. . Your data is right on. We expect -5 at 100k.
    I replaced it all. Only the timing chain, guides, pivot pins, and tensioner are absolutely necessary.
    Timing the balance shafts along with everything else can be tricky but not difficult.
    Those have guides and tensioner too. I did it all .
    The only thing I would do different if I was to do again I would replace crank sprocket. The teeth were pretty worn on mine (130k)
    I actually considered reusing the cam tensioner but thought the guys on this forum would drive to Canada just to punch me in the face of I did.
    1976 Yamaha XS 360
  26. #786
    Feb 24 2004
    Minneapolis
    We'd never do that. I have a friend who lives in Hamilton. I'd just pay him to drive over hunt you down.
  27. #787
    Jan 18 2018
    St.louis Mo
    Has anyone actually had a failure and know what adaptation they were at. I guess my question is, how do we know what’s bad? Or is it more that the timing chain could jump time over actually failing and coming apart.
    Thanks guys.
    2013 A4 Premium Plus Quattro - ADS retrofit installed
  28. #788
    Jun 27 2011
    The old tensioner randomly game apart and you lose all tension on the timing chain. So it skips and kablooey.
    The new tensioner shouldn’t fail, and while the chains can still stretch, it’s unlikely that the chain itself will ever snap. The guides can still wear and break of course. And at a certain point the new tensioner could bottom out and allow the chain to slap around.
    -CP
    2017 Q7 3.0t
  29. #789
    Feb 15 2016
    Cambridge,Ontario
    I think that's exactly what would happen..I think you might actually get a code before it self destructs.
    This is a theory because I can't find someone where the new tensioner failed yet.
    The old tensioner is a ticking time bomb. Can go off at any time,
    1976 Yamaha XS 360
  30. #790
    Jan 18 2018
    St.louis Mo
    That’s why I’m wondering. I know for a fact I have the new tensioner. If the adaptation is at -5.67 on my car is that really cause of concern? Wouldn’t I get some kind of light or something.
    I am planing on doing a stage 2 tune with arp exhaust. So I’m deciding if I want to do the chains first or the tune and wait.
  31. #791
    Dec 28 2006
    Western Maryland
    I would recommend that you make a visual inspection of the tensioner. There are 11 notches of adjustment. If you get to the 11th notch you are out of adjustment so you will no longer be taking up chain slack and at some point the chain will start to jump links.
  32. #792
    Feb 15 2016
    Cambridge,Ontario
    i would not tune with it there.. i was at the 11th notch at 8.5
    although i would not be too concerned.. i would not anger the tensioner gods by tuning it. i would address the stretched chain first.
    1976 Yamaha XS 360
  33. #793
    Jan 18 2018
    St.louis Mo
    Thanks everyone for their input. I’m glad I randomly came across this thread before I did The tune. I do want to keep the car around for at least 3-4 more years. So I’m going to do the chains and everything before I get the tune. Although, I do kind of think that it would be ok, I just don’t want to chance it. And it’s not nearly as expensive for all the parts as I thought it would be
  34. #794
    Jan 18 2018
    St.louis Mo
    How are the timing chain kits from ECS tuning? Are we getting authentic Audi parts from them? Or should I just buy the parts from Audipartsusa?
  35. #795
    Feb 24 2004
    Minneapolis
    Depends on which kit you get at ECS. I think the consensus around here is that given the drama we've seen around this design + the amount of time it takes to do this job, most don't want to risk saving a few bucks on aftermarket parts. I have a pair of Chinese LEDs in my reverse lights. I'd never go cheap for the system that can destroy your engine.
  36. #796
    Jun 27 2011
    I got the Ultimate timing chain kit from ECS and the Schwaben Timing Chain Tool Set as well. All the parts looked high quality and I believe were OEM or Genuine quality. I’d get their kit again, but be aware it still doesn’t have everything you might need. I bought the lower timing cover as well since I’d read that the new one had improved oil distribution channels (it did) and I was worried about bending it on removal (I didn’t but better safe than sorry). I also got a gasket for the upper timing cover to make sure it didn’t leak some bolts that weren’t included and a new crank pulley bolt. Little things that ECS didn’t include. And a few big things like the cam Bridge and lower timing cover I guess. I didn’t have the luxury of extended downtime so I’d rather buy everything I might need and not need it (and return it) than be unprepared and have to hope the dealer has the part in stock and for non-extortionate rates.
    -CP
    2017 Q7 3.0t
  37. #797
    Jan 18 2018
    St.louis Mo
    Getting all my parts from Audiusaparts. All the chains, guides, tensioners, seals and bolts are only going to be $480. That’s not including replacing the bottom. Pretty sure I’ll be able to get that off without damaging it. And my buddy got me a tube of the high dollar sealant from Audi.
    I would say as far as people complaining about how expensive Audi maintenance is, this is coming out to be pretty cheap. I’m getting the tool kit from ecs tuning tho. I was going to get it through Assenmacher but the camshaft holders are on back order for months lol
  38. #798
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    Audi maintenence isn't bad if you do the work yourself. It's when you have to pay someone to do the work that it's expensive.
    2011 A4 Avant Prestige S-Line
  39. #799
    May 10 2015
    Pittsburgh PA
    So I work at an Audi Porsche BMW dealership, and we had 2013 A5 Cabriolet come in with a check engine light ~95k miles. I happened to drive it around the campus to the Audi shop and it seemed to run perfectly fine, but they plugged it in and said the car had excessive timing chain stretch.
    I wish I knew what the code was, but being a 2013 it should have the updated tensioner, so it throwing a CEL when it was on the verge of death aligns with your theory.
  40. #800
    Dec 25 2019
    Cheshire, CT
    Quote Originally Posted by 19birel View Post
    but they plugged it in and said the car had excessive timing chain stretch. I wish I knew what the code was, .....
    Any chance you can find out?
