Page 41 of 57 FirstFirst ... 31394041424351 ... LastLast
Results 1,601 to 1,640 of 2251
  1. #1601
    Veteran Member Three Rings SNice's Avatar
    Aug 06 2019
    Philadelphia
    Has anyone logged any performance data before and after the timing chain/tensioner job? Curious if there is any performance benefit to a smaller camshaft adaptation value?
    2014 A4 B8.5 - AUDI _ EFR 6758 / WPT Stg. 3 Flex-Fuel TUNE / WM Injection / Custom HFC / JHM D-Pipe / AWE FMIC & EXHAUST / APR INTAKE / KW V3
    2002 SV650 - SUZUKI
    1989 nt650 HAWK GT - HONDA
    1972/4 r5/rd350 Hybrid (WIP) - YAMAHA
    1971 r5 350 (basket case) - YAMAHA
  2. #1602
    Dec 01 2020
    2014 Q5 2.0T
    Haven't but I suspect there is not much performance difference. At higher adaptation values and more stretch the timing is running slightly retarded but at just a few degrees I'm not sure it's enough to be meaningful as far as a performance benefit from having it close to 0.
  3. #1603
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    The adaptation value is simply what is needed to put the cam in the expected position. As long as the cam phaser can make the adjustment there should be no change in performance.
  4. #1604
    Senior Member Three Rings Seal1968's Avatar
    Apr 04 2015
    Ontario
    I'm shopping for parts...and note that ECS and others only show timing kits for the TSI ...not the TFSI engines.
    My production date is Oct 2012.
    What is the difference in parts? I assume maybe the cam bridge or one of the rails or something?
  5. #1605
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Seal1968 View Post
    the nomenclature for these engines is an absolute nightmare .. its more about that than the parts. i think VW TSI is Audi TFSI or something like that...
    there is however i think a couple of rail differences between some of the Audi engines as years go on .
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
  6. #1606
    Apr 04 2015
    Ontario
    Smac replied to me...the rails are different for production July 2013 and up...mine was made Oct 2012, so previous versions. All good, doing my homework now.
  7. #1607
    Feb 15 2016
    Cambridge,Ontario
    if you need the timing tool kit i have it . Mine does not have crank holder though. If you need it let me know and we can connect.
    1976 Yamaha XS 360
  8. #1608
    Apr 04 2015
    Ontario
    Thanks, will let you know. Big job.
  9. #1609
    Feb 15 2016
    Cambridge,Ontario
    the big job is getting the front end to where you can work on the car really, once you get the lower timing cover off its not too bad.
    1976 Yamaha XS 360
  10. #1610
    Jan 03 2013
    Baltimore
    -0.13 degrees after replacement head and all other associated timing parts.
    Motor has been running great, except for crappy fuel mileage. Previously I was 27-30mpg as I track all my fill ups in fuelly. Now I am seeing 23-25 mpg. Any thoughts? I've only ran two tanks total since I got it back in early October. PXL_20211204_174211408.jpg
    Sent from my Pixel 6 Pro using Audizine Forum mobile app
  11. #1611
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by elscotto80 View Post
    did you replace rings at all ? resistance due to new rings ? remember Audi went to the substandard rings to eek better fuel economy out of the car .. but to be honest i dont give a crap about fuel economy. i drive cars coz i like them and never even checked mine before and after. but this is a timing thread so i will leave it at that .
    just the head causing lower economy im not sure.
    1976 Yamaha XS 360
  12. #1612
    Jan 03 2013
    Baltimore
    It had new pistons and rings installed a while ago under the original warranty. It's never burned oil since I've owned it since 2012.
  13. #1613
    Feb 15 2016
    Cambridge,Ontario
    oh okay so not likely to be lower fuel consumption due to rings if you have had good mileage since then and have it drop after doing the head... what about throttle body adaption or soemthing like that ? do you think it might need redoing with the new head ? maybe its a characteristic of the new head , it is allowing more air / fuel to flow ?
    a good one for sure
    1976 Yamaha XS 360
  14. #1614
    Jan 03 2013
    Baltimore
    a good one for sure
    That's a good idea. I am not sure if the shop that completed the work did that. I can try that myself with VCDS.
  15. #1615
    Established Member Two Rings mrg_B8TFSi's Avatar
    Dec 24 2021
    Audi 2013 A4 Quattro B8, 6-sp man, Audi 1998 A6 Quattro C5, Ford F250 XL 5.4L 4x4
    Northeast PA
    Hello,
    I'm curious if the following math is true? If the intake cam sprocket tooth is relative to 7.826° as you indicate (360/46 - and I always counted the teeth and I come up with 46) so I agree that each tooth = 7.826°. If I found that my Cam Adaptation is 6.88° refer to image does that mean the that I've stretched the following link distance? 7.826 (is 1 link) so 6.88/7.826 = 0.879 links If this is true than I need to do a complete chain/tensioner upgrade
    Thanks - Mike
  16. #1616
    Dec 01 2020
    2014 Q5 2.0T
    Yes, you need a new timing chain and tensioner (I would do the guides and everything in the timing case while you're in there). At 72K miles I am not surprised....
  17. #1617
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by mrg_B8TFSi View Post
    Hello,
    Thanks - Mike
    Don't over think it. You need new chain,tensioner and guides.
    If you are on an old style tensioner, I'd hurry.
    Sent from my SM-G973W using Audizine Forum mobile app
    1976 Yamaha XS 360
  18. #1618
    Dec 24 2021
    Northeast PA
    Thanks ice,
    Yeah I just bought the kit from FCPEuro, and I am am surprised at only 72k but I don't know the history of the car, I bought it at 68k. I actually just pulled the rubber inspection plug and its the upgraded tensioner (but looks like its on 7th click, yikes!!! I'll start taking off the front end this week, Yeah I'm not overthinking it, thanks.. I have a couple of questions for you, should I remove the cambridge oil screen, on the reinstall? I have heard that is a horrible design they continually blow out and do I need to drain the oil? I just put in Amsoil Euro 5W/40 and its the VW502.0 spec, I'd hate to drum that with only maybe 50miles on that oil. I don't have to drain it to remove the lower timing chain cover, the oil will all be in the pan right?
  19. #1619
    Feb 15 2016
    Cambridge,Ontario
    I did mine on a rebuild so i'm not sure about oil draining but i'm sure others will know.
    If you have the new tensioner there is no reason to panic as it is very reliable. Do it in the summer if you are in a cold climate.
    Yes remove screen..I'm thinking yours will be punched anyway when you take the cam bridge off.
    1976 Yamaha XS 360
  20. #1620
    Veteran Member Four Rings MyDimeIsUp's Avatar
    Dec 04 2019
    West Chester, PA
    Thanks ice,
    Correct no need to drain oil at all. I also didn't replace my tensioner since my car is B8.5 it had the updated tensioner. I was sure to replace all cam chains/guides as well as balance shaft chains/guides. My screen was torn and was stuck in the head so I took the torn screen off and took a pair of pliers and pulled the entire screen out of the cambridge. I'd get rid of the thing since it has no use. We already have an oil filter on the engine. Same thing with the 4.0 twin turbo V8. Everyone removes the oil filter screen before it clogs and starves the turbo of oil.
    2020 BMW M340i xDrive - Mineral Grey
    2012 Audi A6 3.0T Prestige - 034 Stage 1 ECU and TCU | CTS Turbo Intake | 034 Street Density Motor Mounts w/ JHM Trans Insert | ECS X-Pipe
    2013 Audi allroad - RIP
    2007 Toyota corolla
  21. #1621
    Dec 24 2021
    Northeast PA
    Thanks, yeah I was thinking the same thing, but I'm fairly new to this motor, I've been working on the 2.8L 5V way longer than the 2.0 TFSI.
  22. #1622
    Feb 15 2016
    Cambridge,Ontario
    You may want to replace the shoulder bolts the guides pivot on. They have a special coating and mine was all worn off . But I was at 130k miles.
    1976 Yamaha XS 360
  23. #1623
    Dec 04 2019
    West Chester, PA
    Yeah I replaced all my bolts as well. I know technically in the manual they say they don't need to be replaced if removed, but I did so to be safe. I didn't but thread locker on but I'm not losing sleep.
    2007 Toyota corolla
  24. #1624
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by MyDimeIsUp View Post
    I just torqued to spec.
    1976 Yamaha XS 360
  25. #1625
    May 10 2015
    Pittsburgh PA
    I'm doing job within the next couple days, I've read up quite a bit but any tips or tricks from those that have done it ?
  26. #1626
    Dec 24 2021
    Northeast PA
    Yep the kit has the M10 triple squares for all the guides, gonna replace those and new tensioner bolts. Thanks
  27. #1627
    Feb 15 2016
    Cambridge,Ontario
    Lower cover bends easy on removal and leaks. May want a replacement.
    1976 Yamaha XS 360
  28. #1628
    Dec 04 2019
    West Chester, PA
    Do get a replacement. I scored a genuine cover w/ Audi stamping on eBay for $49 w/ shipping and tax (I confirmed every which way that it is in fact genuine and there haven't been any problems). You can also get aftermarket URO and I think Febi from ECS for around $90 (or again check eBay). Trust me you don't want to have oil leaks because you're too cheap to buy a timing cover for ~$90. We had to take our brand new cover off because we didn't seal it correctly and wasted a good couple of hours attempting to not bend it while removing, scraping the oil silicone off, cleaning the cover and the block, and reinstalling and letting sit.
    Quote Originally Posted by 19birel View Post
    If you're going to lock your existing tensioner have a lot of patience. It took my grandfather and I a combined 20mins just to get the lock slid into the tensioner. Between him using a pry bar and attempting to not score any of the aluminum and me getting the lock to slide on while also squeezing the spring clip so the tensioner can slide back... yeah get a bud to help or get the official T40243 tool for like $70+ (though I would rather spend an excruciating 20mins than $70+).
    Make sure to cover the hole to the oil pan so if you drop something it doesn't go into the oil pan.
    The cambridge is easy coming off but HOLY SHIT getting it back on. I'd say that was the most annoying thing of all. I found that using your 15 or 18mm spanner (depending on if you're moving intake or exhaust) to move the camshaft ever so slightly relieves the tension and allows you to slide the cambridge on, though it must be done VERY evenly on the intake and exhaust or else it'll get crooked and you need to pull it off.
    Of course you've heard it before but REMOVE the oil screen from the cambridge. Just another failure point that may result in oil starvation.
    A lot of people forget this. I'm sure you're fine if you don't do this but to be safe take your new chain and submerge it in oil before installing. I wouldn't want a completely dry chain running on plastic guides. I pre-oiled the guides and chains so there would be no risk of scraping on dry chains.
    While you have the balance shaft chains removed, spin the balance shafts back and forth a tiny bit just to confirm that they move freely (balance shafts are known to sometimes seize and lock up the engine).
    On that note while you're in there replace the balance shaft chains. NaptownTuner actually showed that the chains do stretch since he measured the balance shaft tensioner before and after replacing and I think the difference was around 8mm of extension.
    And for shits and giggles if you have an endoscope you may be able to fish it through the hole in the block and possibly get a look at your piston rings (I left my endoscope at home when doing the job so unfortunately I can't confirm if this works or not). that's all I got atm of posting
    2007 Toyota corolla
  29. #1629
    Dec 24 2021
    Northeast PA
    Wow thanks for all the detail there.. yeah I’ve been watching Naptown he’s an Audi genius.. I have the lower cover coming in the kit abs I’m gonna do the balance shafts chain.. doing everything since I’m opening it all up. Gonna spin the shafts and I’ll make sure those sprocket are timed . I’m not doing the oil pump chain or guide.. and I have that CTA kit for relieving the tensioner. Hardest part of this job will be removing the front clip.. I know people say service position is possible, but I can’t see myself putting that lower case on perfectly without having full access. Thanks again and any other tips or suggestions please keep them coming:)
  30. #1630
    Feb 15 2016
    Cambridge,Ontario
    easiest way to get the cam bridge on is to have a buddy just rock the crank back and forth very slightly with a wrench as you slide it on .. chain forces the cams both ways and it slips on.
    1976 Yamaha XS 360
  31. #1631
    May 10 2015
    Pittsburgh PA
    I read that would be a potential issue so I do have a replacement lower cover kit, I got the Febi one. I also bought a new gasket for the upper cover as well.
    I'll be sure to cover the oil pain and keep that in mind for reinstalling the cam bridge! Definitely planning to find and remove the oil screen too!
    As far as the tensioner and lower chain are concerned I did purchase replacements for both. I got the Ultimate kit from ECS (the one with OEM parts) which I believe has all the guides/tensioners
    Thanks for all the great advice guys! I'll post when I'm done with before and after readings of cam adaptation. I've also bought a new crank pulley as well, not sure how many people replace that but I figured the rubber in the stock one (which dampens vibrations) has probably begun to deteriorate so I have a Fluidampr waiting to go on.
    EDIT: as far as the piston rings go I don't have a scope but fortunately my car doesn't really burn oil *knock on wood* at least never enough to require me to top off in between oil changes, so I'm not too worried there!
  32. #1632
    Feb 15 2016
    Cambridge,Ontario
    I can't stress enough how critical it is you get the crank sprocket on correctly and squarely . The alignment tooth " triangle" is not very pronounced and it's easy to get wrong.
    1976 Yamaha XS 360
  33. #1633
    Dec 04 2019
    West Chester, PA
    Yeah putting the cover on is a pain. We just put the car in service position (Unbolted the core support from the top and has it dropdown and angled forward supported with wood blocks on the bottom) we didn't have full access from the front and had to work from the top down. Smudged the silicone when putting the timing cover on and when we ran the car we discovered we were leaking a tiny bit of oil.
    If you don't have the long bolts to slide the core support into service position, here is how I did mine:
    2007 Toyota corolla
  34. #1634
    Veteran Member Four Rings a4lownslow's Avatar
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Here to save another one.. 2015 Q3 2.0T with 99k miles.
    Timing value of 41 degrees
    Safe to say this motor has jumped time but it is still a run and drive. Will be installing new timing components this weekend.Image1640992536.094995.jpgImage1640992560.981558.jpg
  35. #1635
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by a4lownslow View Post
    Not necessarily. Did you check the spool valve to see if it has popped ?
    The one that is responsible for advancing the timing inside the cam bridge.
    1976 Yamaha XS 360
  36. #1636
    Dec 01 2020
    2014 Q5 2.0T
    Agree. Related to the spool valve, which controls the oil flow into the phaser, one of the few times I saw the phase position that high the problem was the that phaser on the intake camshaft was broken (probably an issue with the lock pin not engaging).
    This is a good video that shows how it all works in detail:
    https://www.youtube.com/watch?v=juJ02ZCX9rw
  37. #1637
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    I have not but I have experienced similar values on another A4 that had indeed jumped time. Will update later today..
  38. #1638
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Quote Originally Posted by silver_tt View Post
    Will take a look!
  39. #1639
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Fully extended
  40. #1640
    Dec 01 2020
    2014 Q5 2.0T
    So your chain is stretched for sure..... but with a phase position that high, 41.65 degrees, I still think there's probably something wrong related to the phasing. Let us know!
