    Junior Member Two Rings RUIZRUIZDIEGO's Avatar
    Mar 18 2018
    01 B5 S4,16 A3 E-tron
    Hawthorne California
    TSI injectors on FSI motors
    I have a 2.0T FSI and wonder if I can use the TSI injectors on my car. Will they fit my head and my rail? If so what's the difference between the two. I have Maestro so if they just are a different size I can just scale for the different size.
    2016 Audi S3 Prestige in Mythos Black
    Rays CE28N 18"*9.5" wheels, Michelin Pilot Sport 4S Tires, Billstein B16 PSS10 Coilovers, H&R rear and front Swaybars, APR HPFP, APR Catchcan, APR turbo inlet, Air to Water Intercooled.
    Veteran Member Three Rings StatusQuo's Avatar
    Jun 15 2016
    Northern California
    Quote Originally Posted by RUIZRUIZDIEGO View Post
    You would need FSI injectors. So you have S3 and RS4 injectors to choose from.
    Sent from my ONEPLUS A5000 using Audizine mobile app
    B7 Audi A4 Quattro - Built. Not Bought.
    Upgraded HPFP | RS4 Injectors | RS4 LPFP Controller | 175 Bar PRV | 50/50 E85 | Straightpipe Exhaust | Cold Air Intake | Big Turbo | Front Mount Intercooler | -- The Maestro Community Project --
    Mar 18 2018
    Quote Originally Posted by StatusQuo View Post
    So it's a no fit? I just hear that the TSI injectors are better. One of my injectors is bad and I'm thinking about replacing them all
    Sent from my SM-G955U using Tapatalk
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    I can't remember off the top of my head but I want to say that the tsi injector is bigger at the part that goes into the fuel rail or into the block. I can't remember. But, there are other options out there minus s3 or rs4 injectors
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    It's possible.
    I know someone that has a set of Gen2 B8.5 RS4 TFSI injectors. You'll need to make a custom hardness to run them (spliced from an OEM B7 and OEM B8 harness), and you'll need shims, because the injector body is physically longer on the TFSI injector). Other than that, you'll need to scale in Maestro.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
